Back tires went flat when i didnt drive car for a few weeks?
Old Sep 22, 2008 | 03:50 PM
90HondaCRXSi's Avatar
Default Back tires went flat when i didnt drive car for a few weeks?
I have been letting my crx sit for a few weeks after i got my speeding ticket and have just been working on it as a project. I have noticed that both back tires went flat but not the front ones. This is odd because the back tires are dated newer than the front tires. What could be the cause for this?
Old Sep 22, 2008 | 03:53 PM
sleepingciv's Avatar
Default Re: Back tires went flat when i didnt drive car for a few weeks? (90HondaCRXSi)
how old are they? id it cold where you are storing it? sounds like some dry rot on the tires are they stock tires?
or someone let your air out lol
Old Sep 22, 2008 | 03:59 PM
Default Re: Back tires went flat when i didnt drive car for a few weeks? (sleepingciv)
They are like 2008 and the fronts are 07 but the fronts are fine. Idk who would let the air out of them. The tires are Nitto NT-450 extreme performance btw.
Old Sep 22, 2008 | 04:04 PM
maybe a bad bead? which i doubt, its kinda odd cause my car has been sitting for like 3 weeks and nothing wrong with them. someone probaly messing with ya lol.
did you get them aired back up?
Old Sep 22, 2008 | 04:39 PM
nope i tried to pump them up with this electrical pump thing and it didnt do ****...should i jack it up before i try to pump it up lol? Someone said it might be because the rims are bent but idk why both rear rims would be bent...
Old Sep 22, 2008 | 04:42 PM
ya try and jack it up that might help
are the rims bent lol when its jacked up spin the rear tires and watch from the back on the inside and outside of the rims see if they are
Old Sep 22, 2008 | 04:48 PM
idk if they are bent...i dont think so cause they dont look bent they are acura blades so they better not be bent cause i love them...i will try to jack it up but they been sitting there for almost 2 months sooooooo might neeedd new tiress
Old Sep 22, 2008 | 04:51 PM
O 2 months you said a couple weeks lol thats prob why they flat man lol just throw some air in them should be good to go unless they popped the bead
Old Sep 22, 2008 | 04:54 PM
what do you mean by popped a bead? and in that case would i need new tires
Old Sep 22, 2008 | 04:59 PM
dont need new tire here read this
http://en.wikipedia.org/wiki/Tire_bead
Old Sep 22, 2008 | 05:20 PM
ohh okay
Old Sep 22, 2008 | 05:37 PM
RexShop's Avatar
Just air them back up and see if they go flat again...
If so it could be a small small leak at the valve stem... or you could have punctured them with something (nail/tack/etc) that allows them to leak air very slowly.
Old Sep 22, 2008 | 06:01 PM
gator88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90HondaCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">should i jack it up before i try to pump it up lol? </TD></TR></TABLE>
Usually easier to jack it AFTER it is pumped up, but we're talking tires here.
Sounds liek my subaru. Has same deal go on, aluminum wheels corroded around bead so I took them to a friend who has a tire/alignment shop and he pulled tires, scrubbed clean, and sealed tires back on. Took care of it for about a year and was 20 bucks. time for me to do it again, but i think new steelies and tires are in the future.
Old Sep 22, 2008 | 10:34 PM
salman's Avatar
bad air valve..
Old Sep 23, 2008 | 05:19 PM
Default Re: (salman)
Well me and my friend pumped the tires up and heard a noise as if air was leaking from them...we found what looks like a half-inch knife gash in the side walls of both the rear tires...which is why they went flat and wouldnt pump back up...i guess that means sombody knifed my tires
Old Sep 23, 2008 | 05:42 PM
RexShop's Avatar
That would be a good reason why they won't hold air.
Old Sep 23, 2008 | 07:44 PM
DCRB's Avatar
Default Re: (RexShop)
man that's just messed up.
mike001
May 3, 2007 11:55 AM
mugenpowered
Oct 21, 2006 12:28 PM
devilpuppy
Dec 5, 2004 12:20 PM
sshaikh01
23
Apr 7, 2003 06:20 PM
