b16 on Ls need help.
okay i know the b16 head fits on the Ls block to go Ls vtec. now does the bhead just drop on the block and runs or some slight changes. let me know or give me some advice on putting the b16 head on the Ls block to go Ls vtec. thanks
You need an oil feed line to go to the head. You also need to get a b16 water pump to match the cam gears.
Check out the FAQ, all sorts of info on LS-VTEC
https://honda-tech.com/zerothread/1676914 everything you need to know about ls/vtec
