Damn car problems
Iok a couple days ago my car wouldnt start so i know i have eliminated a couple of things the starter is brand new the car is cranking but not starting the timing belt didnt snap so it boiled down to the distributor so i put a new coil pack and new ignitor in and still no spark i dont know what the problem could be maybe my ecu o yea ant the fuel pump is brand new so its not that either so any ideas would help
Modified by 93daintegra at 9:48 AM 9/22/2008
dude, try using some punctuation. Your post is VERY hard to read.
My car died on the road a couple years ago, turned out my ignition switch harness fried. If you have a Helms manual there should be a troubleshooting procedure you can do to check it.
mine used to have problem starting during hot summer days or after a long ride. Same thing, it cranks but doesn't turn over. Sometimes I had to sit for as long as 20 min before it could start. A common problem is the Main Fuel Relay, you need to resolder the connections if it's cracked. I just bought a brand new one instead, around $50 at the dealership. So far, it has not had that problem ever since.
yea would the main relay stop the car from havin spark ? casue thats what my problem is the car wont spark nothin to do with the fuel or fuel pump.
well I had a honda that was cranking but would not start for a while. I would push start it and it would start right off the bat but not when I would crank it. My buddy said to change my battery. I did and the car is like brand new!!!!!
JimmyM86
Oct 23, 2007 06:15 PM
