Snapped valve cover bolt.
Old Sep 22, 2008 | 07:51 AM
rockcity's Avatar
Default Snapped valve cover bolt.
In a moment of complete ignorance, I accidentally over tightened the front left (looking at the car from the front) bolt that fastens the valve cover to the engine. The nut snapped right off. I do not have time to take the valve cover off now as I have to go to school. Is the bolt easily replaced? I am going to the junkyard tomorrow for a few things and I should be able to get the nut and bolt there at the junk yard.
Old Sep 22, 2008 | 07:56 AM
efjones9's Avatar
Default Re: Snapped valve cover bolt. (rockcity)
yes get a 12mm long socket and u can get it off that way. get extra ones just incase it hapens agian, they are pocket items at da junkyard
Old Sep 22, 2008 | 07:57 AM
rockcity's Avatar
Default Re: Snapped valve cover bolt. (efjones9)
Good deal, thanks man.
Old Sep 22, 2008 | 07:58 AM
gearhead16's Avatar
once you pull your valve comber off youll see where it broke and look further down and youll see the its a stud with a nut on it at the bottom its a 5 min fix just unscrew old and put in new one
Old Sep 22, 2008 | 09:28 AM
Wasuri's Avatar
New User
Might as well order parts new from honda and get new gaskets!
At least thats what I do.
Also valve cover tq is about 7lbs. Not much at all. GL in the future! Just hope you don't break one that you have to use an extractor next time.
edit- did all my posts get removed or archived? I coulda sworn I had more than 1!!!
Old Sep 22, 2008 | 12:11 PM
rockcity's Avatar
Default Re: Snapped valve cover bolt. (Wasuri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wasuri &raquo;</TD></TR><TR><TD CLASS="quote">Might as well order parts new from honda and get new gaskets!
edit- did all my posts get removed or archived? I coulda sworn I had more than 1!!!</TD></TR></TABLE>
Well, the gasket and seals are all new; that's how I snapped the bolt.
boriquaabe718
Jan 14, 2015 02:44 PM
99accordsedanforsale
Classic Hondas
Nov 12, 2007 07:24 AM
Cashieboi
Oct 16, 2006 09:28 PM
genetsang
Mar 25, 2004 02:40 PM
genetsang
Mar 25, 2004 02:34 PM
