Rsx Header
Old Sep 22, 2008 | 07:02 AM
DC2 Maggio's Avatar
Default Rsx Header
Hey guys i'm picking up a Rsx-s 2006 this friday. I have been doing my research on minor upgrades such as bolt ons. I have already picked up an im, throttle body and intake. I wanted to get a good header that puts down some serious power. I have seen the R-Crew Header and how much power it can make. But unfortunately I understand that this is only applicable for either a 94-01 dc2 integra or a civic. Just wondering if anyone has a good header that is making good power on a dc5 body.
Thanks alot guys
Old Sep 22, 2008 | 07:21 AM
simonEp3's Avatar
Default Re: Rsx Header (DC2 Maggio)
It depends how much you wanna spend the Buddy club header is great, DC header is a little more affordable but also pretty decent. If you get a race header you definitely need to get some ESMM's or innovative mounts and if you can afford it Kpro.
Old Sep 22, 2008 | 07:41 AM
DC2 Maggio's Avatar
yea i already purchased k pro. i think i definately need to purchase those esmm or else my header will probably crack. that buddy club header looks like it makes some series power
Old Sep 22, 2008 | 01:00 PM
DC2 Maggio's Avatar
any others?
Old Sep 22, 2008 | 05:16 PM
dc5RickK20's Avatar
seems like you got some cash to toss around have you looked at the toda header?
do you want to stay all motor or do you plan to go boost later?
Old Sep 22, 2008 | 08:40 PM
iVteCmMdc5's Avatar
Default Re: (DC2 Maggio)
well i got a dc/rh and it been nuttin but prombs soo def dont wanna go with that if i had a choice again i got wit a BC/RH spend the xtra money it worth it in the end..
Old Sep 22, 2008 | 08:46 PM
WhiteOnRice's Avatar
I have a ceramic DCRH and have had zero problems at all. I've probably installed/uninstalled it nearly 10 times. Had it w/o esmm, a torque dampener or upgraded mounts for ~8 months. Just removed it 2 days ago and it is still in great condition (rusting like ceramic does but no cracking).
Old Sep 22, 2008 | 09:28 PM
iVteCmMdc5's Avatar
Default Re: (WhiteOnRice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">I have a ceramic DCRH and have had zero problems at all. I've probably installed/uninstalled it nearly 10 times. Had it w/o esmm, a torque dampener or upgraded mounts for ~8 months. Just removed it 2 days ago and it is still in great condition (rusting like ceramic does but no cracking).</TD></TR></TABLE>
weird ive had nothing but prombs with mine ive had it off and on like 2-3 times now and it has cracks in it all over the place but now that i welded it up near the flange it been ok but i dont have mounts with mine so im sure that has something to do with it.
Old Sep 23, 2008 | 06:14 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (iVteCmMdc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteCmMdc5 &raquo;</TD></TR><TR><TD CLASS="quote">
weird ive had nothing but prombs with mine ive had it off and on like 2-3 times now and it has cracks in it all over the place but now that i welded it up near the flange it been ok but i dont have mounts with mine so im sure that has something to do with it. </TD></TR></TABLE>
Very likely the mounts are the problem. I thought I heard actually more problems with fitment and sway bar hitting with the Buddy Club than DC
Old Sep 23, 2008 | 01:09 PM
DC2 Maggio's Avatar
I have narrowed it down to 2 headers. Either the SSR Header or the Hytech Header. Both make amazing power. Now the question is do i need to install energy suspension motor mounts or inserts?
Old Sep 23, 2008 | 01:38 PM
firemanG's Avatar
get the full motor mounts from innovative. They're much better than the inserts.
Old Sep 23, 2008 | 04:20 PM
DC5 Maggio's Avatar
so its pretty much like doing a motor swap. i take out the oem mounts and replace with innovative?
Old Sep 23, 2008 | 05:45 PM
firemanG's Avatar
Default Re: (DC5 Maggio)
yeah but no need to take out the motor if thats what you meant about "motor swap" just use a jack to hold the motor and swap the mounts.. check this out. http://forums.clubrsx.com/showthread.php?t=549754
Old Sep 24, 2008 | 03:14 PM
DC5 Maggio's Avatar
fireman to the rescue. thanks alot man. is that your bom rsx in ur avatar? and also wuts ur setup like header w. which mounts?
Old Sep 25, 2008 | 01:05 AM
firemanG's Avatar
np doode! Yeah that's my car in the avy. I'm running buddyclub rh with the innovative motor mount (60a street).
Old Sep 25, 2008 | 03:42 PM
DC5 Maggio's Avatar
nice! so no problems with the buddy club springs or super stiffness of the mounts? isn't it an uncomfortable ride. i got 60a hasport mounts in my dc2 and everything vibrates
Old Sep 26, 2008 | 01:52 AM
firemanG's Avatar
yeah everything vibrates.. its whats gonna happen when you stiffen up your motor mounts so theres no avoiding it.. however the vibrations dont bother me at all. From what i hear the inovative mm vibrations arent as bad as having the inserts. As for my headers, well i just barely got it so yeah.. oviously no problems haha.
Old Sep 26, 2008 | 06:10 AM
DC5 Maggio's Avatar
Im wonderin about the ingalls td. probably better off grabbin the inovative mm though. The last thing i want to do is pick up my dc5 and have it vibrate like my dc2 did with hasports. I dont think it will be as bad though.
Old Sep 26, 2008 | 08:09 AM
firemanG's Avatar
nah trust me your better off with the motor mounts than anything. Since you say your getting kpro you can always raise the idol of your car that way you won't feel the vibrations
Old Sep 26, 2008 | 01:09 PM
Dowski's Avatar
Default Re: (firemanG)
I run the bcrh and I would highly recommend it. Sounds great, and got a nice power gain. Also, I installed the ingalls torque dampener and it seems to be a pretty good product. The vibration from stock is noticeable, but it is pretty minor. Shifting is smoother, and wheel hop from first to second is virtually eliminated. I actually bought the esmm's but have not installed them yet. Was thinking about doing so but you guys got me a little shook saying that it causes alot of vibration. One problem I am having though, is that I did not buy a sway bar with the bigger opening for an after market header, so I was changing the oil last night and noticed that the springs on my header are gone, and my stock front sway is slightly shifted towards the passenger side.
HiChanDC2R
Honda Civic (2006 - 2015)
May 21, 2011 07:32 PM
amimaxima
Jan 26, 2009 03:56 AM
redDAinteg
Jun 15, 2005 09:49 AM
lazyguy
Apr 16, 2002 07:47 PM
