95 coupe for sale (MD/PA/WV)
Well I finally got my GTI so my civic is now for sale. Here is the run down...
-1995 Civic EX
-2 Door, 5 Speed, Frost White
-completely stock d16z6
-121,xxx miles (low for a '95)
-The plugs, wires, dizzy cap and rotor, tranny fluid, fuel filter, rear ABS speed sensors, and thermostat all were replaced at 95k miles
-The timing belt, water pump, idler, and v-belts were all replaced at 100k miles
-The safc II that is shown in the pics will not be included (unless buyer wants it)
-The car is 100% stock other than shifter bushings, a b&m short throw with ****, and the safc II which was just installed since I had it laying around from my old car.
The good...
-The motor runs very good and has low miles.
-Doesn't seem to leak or burn oil
-Gets excellent gas mileage (near 40mpg highway!!!)
The bad...
-most recently and probably the biggest issue is last week the clutch started acting up. i can still drive it but it has nearly no pedal feel and the clutch begins to grab much sooner than it did. It is a little tough to get into gear from neutral as well. I assume the clutch is going bad and from what i have seen, OEM parts seem reasonably priced.
-the infamous honda rust is there on both rear quarter panels
-it needs 3 new tires (i just put one new tire on last week from a flat)
-it needs new shocks
-needs a new horn
-the a/c doesn't blow cold air (i don't know if it needs charged or a new compressor?)
-the car is 14 years old so i am not going to tell you it is a showroom condition car.
i dont really have a set price. kelly blue book shows a price of $2,780 in fair condition. i am willing to take a price a good bit below this as i don't need it sitting around my parents driveway anymore! i would start at $2,000 OBO.
the car is located in hagerstown, MD zip code 21740. The vin is avail upon request. If you have any other questions let me know. Thanks!
Modified by judunty84 at 12:21 AM 9/22/2008
Modified by judunty84 at 12:19 AM 9/25/2008
-1995 Civic EX
The good...
The bad...
-needs a new horn
