del sol ls swap motor mount problem
Old Sep 21, 2008 | 05:32 PM
mymomsdrunk's Avatar
Default del sol ls swap motor mount problem
cant get this mount to line up?!?! this is the lower mount that came off the b15 motor, just wondering if this will work or do i need a mount from the doch vtec del sol?
Old Sep 21, 2008 | 05:42 PM
94EG8's Avatar
Seagull Management
Default Re: del sol ls swap motor mount problem (mymomsdrunk)
the metal bracket part must be from an integra or del sol vtec. the rubber mount part must be for a del sol or civic. If you can get a complete del sol vtec mount/bracket it should just bolt up.
Old Sep 21, 2008 | 05:52 PM
Default Re: del sol ls swap motor mount problem (94EG8)
the metal bracket is from the del sol, i have an integra i am swaping everything from, the one in the integra looks to long so i figured it wouldnt fit.
crimsonv4mpire
Aug 7, 2008 06:20 PM
hotimportcrx
Oct 23, 2005 03:37 PM
Sliced Beard
Mar 26, 2004 02:36 AM
