Transmission & Drivetrain Gearboxes, Differentials, Clutches
*LS Transmission Questions*
Old Sep 21, 2008 | 08:59 AM
extremeracer's Avatar
Default *LS Transmission Questions*
Hi guys
I know this might sound like a noob question - but here goes
I am planning to build a turbo LS/Vtec for my street/strip orientated Civic. I will probably be making around 400whp at this stage (more later on) and I've got an LS transmission for the car.
My question is the following:
1) Can you interchange gears between the B16A (S4C) tranny and the LS tranny.
ie 2nd and 3rd
OR
2) Are there companies that make Final Drive's for the LS tranny - im looking for a higher final drive ratio
I am basically trying to find a sollution to using the LS tranny but getting the gear ratios closer to the GSR or B16A specs - to improve acceleration and prevent boost drop off between 1st and 2nd gear !!
All your help will be appreciated
Old Sep 21, 2008 | 06:36 PM
Aquafina's Avatar
Change 3-4-5 and FD out for GSR gears and you have the same gearing as a GSR.
Old Sep 24, 2008 | 03:33 AM
turbo_charged_bee's Avatar
Default Re: *LS Transmission Questions* (extremeracer)
i have a LS/Vtec turbo charged set up.
My tranny has the following gears, and it works great.
1st gear - GSR/LS
2nd gear - GSR/LS
3rd gear - B16/ITR
4th gear - B16/ITR
5th gear - LS
Final drive 4.400 with JDM 98 spec R LSD
Perfect for a daily driven. The 5th gear helps save your turbo
Old Sep 25, 2008 | 04:32 AM
Default Re: *LS Transmission Questions* (turbo_charged_bee)
Thanx for the reply, so will the B16A (S4C) gears fit onto the LS main shaft or do I need to swap the main shafts between the the two transmissions ?
What im actually asking is: What exactly does it entail to do the gear swaps ??
Old Sep 26, 2008 | 12:04 AM
Side by side comparison, b16 and LS mainshaft are the same.
You can use either one, which ever one looks less beat up.
Yes they are swap-able.
Jux keep in mind that OBD0 B-series trannies is not compatible with OBD1 and OBD2. But OBD1 and OBD2 B-series trannies are.
As for countershaft, it depends on what final drive ratio you want.
4.400 = B16 final ring gear + b16 conuntershaft
4.266 = LS final ring gear + LS counter shaft
*B16 final ring gear will NOT work with LS countershaft
*LS final ring gear will NOT work with B16 countershaft
Good luck
Old Jan 3, 2009 | 02:54 PM
JdMaddKanic's Avatar
I have Three transmissions at my dispossal currently and I am trying to build a hybrid set-up.Want the acceleration of a ITR but the top end of and LS or GS-R. What combo's are ideal for 170MPH reliable top end naturally aspirated raping status.
Old Jan 3, 2009 | 08:54 PM
Honda Bull's Avatar
You'll only need to swap mainshafts if you want the B16 1st/2nd gears. 3-5 are interchangeable as long as you keep 3-4 of the B16 together. Along with those two gears, you need the B16/GSR/ITR synchro sleeve/hub/synchros rings and springs/shift fork for 3-4.
If you want to do the FD swap, you'll need the B16 ring gear with B16 countershaft. You can also use the GSR/ITR ring gear pieces, but you'll need the larger diff to go along with it.
dannyhoo
Jul 7, 2015 12:48 PM
b18_spoon
May 1, 2012 09:02 AM
b20vtecEK
Jan 25, 2005 05:27 AM
Rain n Blood
Aug 18, 2004 04:51 PM
Allstar
Oct 24, 2001 09:41 PM
