DC heating/center console problem
Old Sep 21, 2008 | 08:13 AM
dapek's Avatar
Default DC heating/climate control problem
EDIT: I have figured out that the wiring harness wasn't plugged into the 5 spots or so that it was supposed to be. I took out the climate control and found that they were plugged in but when i followed the wiring none of them were hooked up. Where do these go guys/chicks? Thanks
OLD: So it's getting closer to winter and i will be needing to use my heater soon there's just one problem...it won't work! When I try to use it at all or turn it on at all no air comes out of any vents. None of the buttons light up when I push them too they just push in. I'm thinking it could be the heater relay or something? If anyone can help let me know
Modified by dapek at 10:57 AM 9/22/2008
Modified by dapek at 10:37 AM 9/28/2008
Old Sep 21, 2008 | 10:07 AM
garados's Avatar
Default Re: DC heating/center console problem (dapek)
I'd take out the climate controls and make sure everything is plugged in. If they are, backtrack to the fuses and relays. If air isn't coming out, the fan isn't turning on. I don't remember if that's a fuse or a relay or if the fuse/relay is under the dash or in the engine bay.
Old Sep 21, 2008 | 10:36 AM
dapek's Avatar
Default Re: DC heating/center console problem (garados)
Thanks man i'm trying that right now and i'll see how it goes
Old Sep 21, 2008 | 01:52 PM
dapek's Avatar
So everything is plugged in and the heating motor relay is good but it must be a fuse because the lights and everything aren't working on the part that you choose where the air hits as well as the switch to slide it on? Does anyone know where the fuse for this part of the center console is?? i searched and found nothing
Old Sep 21, 2008 | 09:11 PM
dapek's Avatar
45 views and one person helping? Dang peeping toms
Old Sep 21, 2008 | 10:07 PM
garados's Avatar
check this http://spoon.org/civic/pics/In...l.jpg left column, third one up, the 7.5 amp fuse under the dash. I wonder if that's the one. There's gotta be a relay (or three) in the under-hood box that corresponds to that fuse.
Old Sep 22, 2008 | 09:57 AM
dapek's Avatar
thanks but shoot man fuse is good, I checked the relays, fuses, and pulled out the climate control and everything is plugged in. The emergency lights button and rear defroster work but not the entire climate control part. It doesn't light up nor turn on. Shoot i'll keep trying if anyone else knows anything that would be great
Old Sep 22, 2008 | 03:04 PM
dapek's Avatar
Old Sep 23, 2008 | 03:32 PM
dapek's Avatar
up for checkity checkin
Old Sep 23, 2008 | 03:42 PM
scamp91ex's Avatar
if the fuses and relays are good check for continuity from the fusebox to the climate control unit. unless you have been under the dash doin stuff i don't know how the wiring could have gone bad, but it's worth a shot.
Old Sep 23, 2008 | 05:38 PM
dapek's Avatar
Default Re: DC heating/center console problem (scamp91ex)
thanks man thats what i figured i'd have to do, ill check it out
Old Sep 24, 2008 | 04:12 PM
dapek's Avatar
bumpity bump
Old Sep 24, 2008 | 05:38 PM
dapek's Avatar
so i got under the dash to check the wiring out as well...none of the wiring harness from the climate control was plugged in! Now my question is, where does it go? There are a few different ones??????
Old Sep 24, 2008 | 08:16 PM
garados's Avatar
well, they should be pretty easy to figure out ... i mean the plug size, number of wires, and maybe even wire colors should match up. Anyways, if it's totally weird down there, a picture would help Good job finding the problem!
Old Sep 24, 2008 | 09:03 PM
dapek's Avatar
nice thanks for helpin man Do you know if they are supposed to all plug into the interior fuse box around there? I'll get a pic asap
Old Sep 24, 2008 | 09:55 PM
garados's Avatar
well, if the plugs you traced back from the climate controls terminate at the fuse box, then probably. probably have to plug into the back of the fuse box or the connections a little higher than the fuse box.
Old Sep 25, 2008 | 06:47 AM
dapek's Avatar
alright nice i'm gonna check around that area. Thanks for all the help again
Old Sep 25, 2008 | 07:03 PM
dapek's Avatar
Default Re: DC heating/center console problem. (dapek)
Ok so i found two spots where two of them connect but now i'm looking for the other 2 or 3. There are two connections that sit above the ecu under the dash and those are both for it but now i'm searchin for the others haha any other help from anyone too would help
Old Sep 28, 2008 | 09:37 AM
dapek's Avatar
bump it up
Dekorum
Jun 1, 2008 09:05 PM
ZakkWylde
May 24, 2007 05:18 AM
Tippyman
10
Jul 30, 2006 09:09 PM
supracrx
Jun 8, 2006 06:48 AM
JDubya
Jul 19, 2002 08:34 PM
