European Honda CRX D16A5 DOHC axles, spark plug wires?
Old Sep 21, 2008 | 07:33 AM
eighty9crx's Avatar
Default I need European Honda CRX D16Z5 or ZC DOHC c.v. axles?
I have a 1991 Honda CRX German model with the DOHC D16Z5 engine and 5 speed transmission, and I have been told that it is the same as the Japanese ZC cause of the bulge in the hood and it's 124 hp rating. My question is that I need c.v. axles for the car. The axle on the LH side goes into a halfshaft and then into the transmission. The dealership wants 900 euros a piece per axle and that equivalates to over $1400 dollars. Are there any us model axles that are the same length as the CRX ZC DOHC ? I need axles bad so I can pass the German inspection. There aren't any shops here that rebuild axles as they just replace them with new from factory. I don't want to have to bite that bullet. All help will be appreciated.
Modified by eighty9crx at 3:33 PM 9/21/2008
Modified by eighty9crx at 11:02 AM 9/24/2008
Old Sep 21, 2008 | 07:55 AM
sleepingciv's Avatar
Default Re: European Honda CRX D16A5 DOHC axles, spark plug wires? (eighty9crx)
the dohc zc uses a midsfaft with 2 outter cv shafts. your car should have a midshaft and i believe you can use the usdm 90-93 integra axles.so you can not use the us si axles. as for the wires the i would assume the jdm dohc zc wires are the same and the 88-89 integra are the same also.
Da ist ein Affe in ihrem Garten
Modified by sleepingciv at 9:02 AM 9/21/2008
Old Sep 21, 2008 | 11:16 AM
eighty9crx's Avatar
Default Re: European Honda CRX D16A5 DOHC axles, spark plug wires? (sleepingciv)
Thanks dude, I will be sure to check it out.
Modified by eighty9crx at 3:23 PM 9/21/2008
Old Sep 23, 2008 | 01:59 AM
eighty9crx's Avatar
To the top
Old Sep 24, 2008 | 07:03 AM
eighty9crx's Avatar
To the top.
Anybody please help?
Old Sep 24, 2008 | 08:31 AM
jlicrx's Avatar
Default Re: (eighty9crx)
the 90-93 Integra axles (one left and one right) are what you need - you will need to remove the dust rings on the inside of the knuckle and on the CV joint to keep them from binding - 88-89 Integra D16A1 spark plug wires fit the D16Z5
Old Sep 25, 2008 | 01:54 AM
eighty9crx's Avatar
Default Re: (jlicrx)
What would be the exact model Integra, and engine that the cv axles would be for.
Old Sep 25, 2008 | 07:21 AM
jlicrx's Avatar
all 90-93 Integra models have the B18A1 engine (except GSR which has B17) - all models use the same axles
Modified by jlicrx at 1:45 PM 9/25/2008
Old Sep 26, 2008 | 06:52 AM
eighty9crx's Avatar
Thanks alot!
crxguy406
Jun 29, 2013 09:50 PM
onefiine69
22
Mar 29, 2005 06:34 PM
shivic
Aug 11, 2004 06:12 PM
JDMVTEC
Nov 2, 2003 05:57 PM
kokujin
Apr 11, 2002 06:50 AM
