Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help to shim diff, the clutch housing
Old Sep 21, 2008 | 07:12 AM
b20beast83's Avatar
Default Help to shim diff, the clutch housing
How do i shim the diff? the clutch housing side
I lost my shim and i need to purchase one and re shim.
What should the clearance be on the clutch housing side?
Old Sep 21, 2008 | 11:37 PM
Mista Bone's Avatar
D Tranny Guru
shim goes in the other case.
Old Sep 22, 2008 | 04:23 AM
b20beast83's Avatar
Default Re: (Mista Bone)
there is no shim in the clutch housing side?
the clearance on the other side should be 0 right
meaning a feeler guage wont be able to go thru?
Is this correct
Old Sep 23, 2008 | 08:32 AM
Dang EG's Avatar
Default Re: (b20beast83)
I dont know if this is for both LSD and open differential but for a LSD, there should be no more then .004 clearance with the feeler gauge.
I believe I did the MAX clearance where you couldnt fit anything in and now my tranny is giving a little hard time changing into other gears from neutral at low rpm's. Might be one of my reasons why my shaft did not spin freely when it was complete (I didnt know it was supposed too)
rotary_fever
Sep 15, 2014 06:27 PM
Shake'nBakeCrew
May 12, 2010 02:37 PM
Creator
Nov 28, 2004 06:09 PM
xplhavoc
Feb 23, 2004 07:03 PM
Dee
Mar 14, 2002 05:34 PM
