timming belt
Old Sep 21, 2008 | 05:50 AM
yamahamers's Avatar
Default timming belt
Hello there, i have a 1994 accord ex that the timing belt broke while running does this mean i have bent vavles? should i pull the head to be sure ?it made no noise when it quit i look at the head and none of the valve spring are compressed-thanks yamahamers
Old Sep 21, 2008 | 12:46 PM
Mr Yamada's Avatar
Default Re: timming belt (yamahamers)
remove the valve cover, remove the spark plugs.
Next rotate the CRANK 90 degrees away from TDC, this puts the pistons 1/2 way in cylinders; out of the way of valves.
Now you can rotate the CAM, when the CAM LOBES of any cylinder are pointing to the 4 'O'clock and 7'O'clock position, that cylinder has valves closed.
Then use a tight fitting hose in the spark plug hole and "manually" blow into the cylinder, if you feel no back pressure there is a bent valve.
This method will save you time or money from putting on a new T-belt for a compression check, only to find a bent valve later on.
sk8shorty012
Mar 27, 2016 05:23 AM
raze38015
Apr 20, 2008 08:27 AM
SikAuto
Mar 15, 2008 04:00 PM
ixlr8gta91
Feb 23, 2008 12:40 PM
Shannons52
Jul 14, 2003 07:25 PM
