type R flywheel with b18a1
alright I have a question, I picked myself up a type R flywheel, and I had bought a new clutch kit prior to buying the flywheel, and obviously the 91 Teg pressure plate doesn't fit the type R flywheel. My question is what clutch kit would I need to use, or is this a situation where I would need to frankenstein it with different parts?
Thanks for the help in advance!
The pressure plate DOES fit the ITR flywheel. The important thing to know is the clutch disk, it much be matched up with whatever tranny you are using.
90-91 small spline design
92+ large spline
92+ large spline
if that's the case then I don't have the correct pressure plate as the holes do not line up. Also I am using a Y1 tranny.
luderone
Sep 13, 2003 02:01 PM
