lsvtec no crank on start.....please help
Old Sep 20, 2008 | 04:43 PM
SDP190416's Avatar
Default lsvtec no crank on start.....please help
LSVTEC B18B1/ B16 P/P HEAD, IHE, VAFC, MSD 6A, chip P28 ecu.
drove my car home and everything was working fine. I tried starting it the next day, i wasnt getting no crank on the starter and i notice i dont have any fuel press on my my gauge. i also noticed when my car is turned to the on position, the oil press and battery lamp stays on and its dim.
Troubleshooting: checked the starter in accordance with the honda dealership manual and my starter works fine, it spins and the gear pops out when i applied 12v on the starter, my fuel pump is the same way. i checked all the fuses and none of them were burnt or popped, i changed the engine harness and power cable from the batt to the starter, i checked all my harnesses on my ecu and everything looks normal. i also check the main and starter relay. i did a test on the main relay and the plug connecter and it checks good. i also checked the starter relay, i was supposed to get a continuity when i applied 12v on B,D plug and i can hear it click, but im not getting any continuity.
i really need some help, i am tired of chasing wires. thanks
Old Sep 20, 2008 | 04:55 PM
infumis's Avatar
check your grounds
Old Sep 21, 2008 | 10:10 AM
SDP190416's Avatar
Default Re: (infumis)
i checkd the battery, valve cover, tranny shell to the chasis ground and everything looks okay. does anyone had this type of problems before? NO crank on starter and no fuel pressure. what should i check next.
Old Sep 21, 2008 | 10:17 AM
infumis's Avatar
when you turn your key to on(not start) do you hear a click when your engine light comes on and a click again when the engine light goes off. if not check your main relay. its a black box with a harness coming out of it above your hood release and should be on the a 10mm bolt right above it. you can take the cover off it and check the soldering of the points. if the solder is dripped down then either re solder the points or get a new main relay.
Old Sep 22, 2008 | 12:39 AM
civic95hbvtec's Avatar
Thermostat ground
99 SI TYPE R
Mar 11, 2014 05:44 AM
SDP190416
Sep 21, 2008 10:45 AM
FSS13foxtrot
Apr 1, 2008 08:05 PM
siblue_gzer
Mar 9, 2006 12:49 PM
SJR
Jan 28, 2005 12:50 PM
