oil leak :(
i changed my spark plugs today in my 93 civic si with a 95ls b18b engine and there was oil on the spark plugs
what is the problem and should i be scared
also it does not smoke at all when driving
Top of the plugs?
I bet it's just the spark plug tube gaskets leaking. They fit into the valve cover, cheap and easy. I would do a valve cover gasket too while you're at it.
