How hard is to put EVO RECARO seats in civic hatchback?
Old Sep 20, 2008 | 03:58 PM
95GSRBOI's Avatar
Default How hard is to put EVO RECARO seats in civic hatchback?
My boy just gave me the complete front and back seats from his EVO.. I wonder how hard is it to convert it into my hatch. Currently I have del sol seats in my car, but am I able to swap the brackets over to the EVO seats and drop it in? If you can install forum, please copy and paste or from any site that someone have done this before... I seen it happen in integra, so I know there's a way. Just need more info... I did a little research and some people used these http://www.jhpusa.com/store/pc...ry=67 rails for evo 3, but how would I know which one I can used with the 2006 evo mr black w/ red stitch seat.... thanks
Here' seome Pix of the seat:
Modified by 95GSRBOI at 9:08 AM 9/21/2008
Old Sep 20, 2008 | 07:48 PM
crapanese's Avatar
fabrication is your friend. nothing is impossible.
i would say seat swaps are probably the easiest thing to do. maybe not the backs. but the fronts for sure.
they are recaro's so you might be able to just use a universal rail, like a recaro or bride rail. ive always just used OEM rails and just swapped the whole assembly or fabbed 2 sets together.
Old Sep 20, 2008 | 09:56 PM
95GSRBOI's Avatar
Default Re: (crapanese)
Anyone else out there have convert the evo seats in their civic? I'm sure I am not the only person who would want to put those hot seats in a hatcback. Any ideas will help.. thanks
Old Sep 20, 2008 | 10:06 PM
2brown4u's Avatar
ive been thinking about doing this good luck with the info
Old Sep 20, 2008 | 11:18 PM
01-0720's Avatar
Default Re: (2brown4u)
you dont need to convert anything, or get anything custom
just get rails for jdm dc2 itr or ek9 ctr recaro srds, either the stock recaro rails that come on the seats or others like memory fab or vision ultra lows
the evo recaro's rails mount to the bottom of the seat just the dc2 ek9 recaros do
Old Sep 21, 2008 | 07:55 AM
95GSRBOI's Avatar
Default Re: How hard is to put EVO RECARO seats in civic hatchback? (95GSRBOI)
What you guys think of these?
Detail Description:
Racing Seat Bracket is made of high tensile steel with easy installations. These seat brackets will bolt up to any Recaro or Sparco seat.
Fit 1992-2000 Honda Civic (all model)
Old Sep 21, 2008 | 08:00 AM
JDMADD1CT's Avatar
Default Re: (01-0720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">you dont need to convert anything, or get anything custom
the evo recaro's rails mount to the bottom of the seat just the dc2 ek9 recaros do </TD></TR></TABLE>
just do EXACTLY what he said to do...cant get any easier than that. those are the rails you need & you KNOW are gonna work. dont get rails you're not too sure will fit or not
Old Sep 21, 2008 | 12:09 PM
Sparkles's Avatar
Default Re: (JDMADD1CT)
All Recaro recliable seats like those in the jdm itr and evo mount the same way. Go buy some Vision One Touch seat rails and simply bolt them in
Old Sep 22, 2008 | 06:14 AM
torontoefsedan's Avatar
^^ not true. my sr2's were wider than the rails i had... had to fab some adapters out of aluminum.
Old Sep 22, 2008 | 06:28 AM
EJ8freek's Avatar
I don't know man, but those seats are ugly.
Old Sep 22, 2008 | 07:13 AM
NA4life's Avatar
Default Re: (EJ8freek)
if you guys didnt know...the rails/sliders on the Evos are built into the seat base...all you need to do is take off the original mounting brackets from the rails and use custom mounts.
Old Sep 22, 2008 | 10:06 AM
743 Stunna's Avatar
Default Re: (NA4life)
ive got evo 8 seat sitting next to my dc waiting to go in but i havent even looked at them to see whats needed yet. interested in the jdm rails that come on the recaro's has anyone tried this?
Old Sep 22, 2008 | 12:30 PM
01-0720's Avatar
Default Re: (743 Stunna)
look up and read my post
Old Sep 22, 2008 | 01:31 PM
NA4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">look up and read my post</TD></TR></TABLE>
When I installed my DC5 Recaros into my Evo 9, the stock OEM rails cannot be taken off since the rail adjuster was built into the OEM seat. I had to buy Recaro rails and I just reused the stock mounts. Unless the Evo 8 seat base are different.
Old Sep 22, 2008 | 01:38 PM
1200 Hobos's Avatar
whatever you do don't buy that trendgear bracket. The alignment on it is probably going to be WAY off.
Old Sep 26, 2008 | 05:00 PM
95GSRBOI's Avatar
Anymore more advice? I realized that the base/rails cannot be removed. The only way is to removed the brackets and install custom brackets. Question is? Where do I get those custom bracket? Any idea?
Old Sep 26, 2008 | 07:51 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRBOI &raquo;</TD></TR><TR><TD CLASS="quote">Anymore more advice? I realized that the base/rails cannot be removed. The only way is to removed the brackets and install custom brackets. Question is? Where do I get those custom bracket? Any idea?</TD></TR></TABLE>
You will need the OEM Evo seats and rails...so make sure the seats your budy gave you are complete. From there you will only need to make custom chassis mounting brackets.
You can remove the chassis mouting bracket on the Evo seats... they're only hold by one bolt on each corner. Once you remove the base aka chassis mounting brackets will come off, then measure the length and make you own base/chassis mounting brackets to bolt it into your Civic.
This is the easiest/cheapest way of doing it. But then again you can fab or order other rails/sliders that are specially made for this conversion but it will cost you more$$$
weaksauce.org
10
Dec 9, 2008 04:56 PM
95GSRBOI
Oct 23, 2008 08:53 PM
95GSRBOI
13
Sep 21, 2008 09:43 PM
216.226.142.95:27016
Apr 4, 2004 11:51 AM
u2civic1
Dec 8, 2002 12:41 PM
