How to change the rear motor mount 93 Accord?
Anyone have a link on a DIY for installing a new rear motor mount? Or possibly some hints or steps? It is a 2 dr EX automatic if that helps.
Thanks in advance!!!
John
John
Oh man, those are fun to do. Start with removing the bracket to the front motor mount and the bolt out of the rear. Remove the fuel filter and charcoal canister(it'll be in the way later) now is the best time to replace the fuel filter. Put a floor jack under the back side of the trans and jack it up as to tilt the back of the motor up as high as you can. Remove the bolts from the rear mount, disconnect the vacuum hose and slide the mount out. Its kind of a fight but it will come out. You may have to rotate the mount around because of the diaphragm on the mount.
Civichatch972
Dec 8, 2002 11:42 AM
