Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
quick transmission question
Old Sep 20, 2008 | 11:14 AM
Blackknight103's Avatar
Default quick transmission question
hey i just noticed that my transmission is a little squicky when the clutch engages with the gear (only first). Its really hard to explain but i just noticed it and i was wondering if I should do something about this or if anyone else has ever had this problem. It just bugs me. I just installed aluminum shifter bushings if that makes any difference.
thnx
Old Sep 20, 2008 | 12:29 PM
civic1234's Avatar
Default Re: quick transmission question (Blackknight103)
If your bushings are anything like energy suspension's urethane bushings then they require lube. I had a squeak back on a car with energy urethane bushing kit... i didnt lube them well enough
Old Sep 20, 2008 | 12:36 PM
hmm. What did you use to lube them?
Old Sep 21, 2008 | 04:17 AM
civic1234's Avatar
Default Re: (Blackknight103)
they had grease that came with the bushings.... i do not know the name of it but it was a clear thick grease, kind of like the grease you put on your brakes to stop squeal.
Old Sep 22, 2008 | 06:21 PM
vtechrex's Avatar
Default Re: (civic1234)
that could also be your throw out bearing does it sound like it is coming from the engine area or from inside the car
Old Sep 25, 2008 | 12:58 PM
FijiBlueFG2's Avatar
Road House
Default Re: (vtechrex)
Mine don't squeak, but there is a mechanical crunch, sort of, when going into first and third. Third is worse(as we all know), but First sometimes will take a second to engage.
Tweakmeister
Jun 14, 2009 07:45 PM
sageuvagony
35
Jun 24, 2007 02:00 PM
theshaunanana
May 31, 2006 11:23 AM
dkhuynh
Oct 15, 2004 08:23 PM
ahead
Jan 30, 2003 06:41 PM
