Will this clutch work for m??
Does anyone know if i can use this clutch on my jdm b16a engine and cable transmission?
http://cgi.ebay.com/ebaymotors...76673
There might be a gold sticker/tag on the front of the tranny. If not, there may not be a real way to tell. Odds are, if you got the tranny with the motor, you either have a S1, J1, or Y1 tranny. The clutch difference between those trannys and the YS1 is the input shaft size.
yes there is a sticker on the tranny. I will check it. i did get the motor and tranny together. I will also check the output shaft size and splines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny-Red »</TD></TR><TR><TD CLASS="quote">You swapping a b16 into ur hatch? or the rex</TD></TR></TABLE>
No I just bought another hatch and im starting from scratch. i didnt feel it was worth taking apart either of the running cars.
Th tag on the transmission reads J1-1006217 and there are 24 teeth/splines on the output shaft. Will the aforementioned clutch work?? How can I tell if this is an LSD tranny??
CapnKrunch
Nov 6, 2008 04:12 AM
BseriesHatch
Nov 13, 2003 08:27 AM
