hasport mounts rattling my windshield
when i get on my car crx on the highway the windshield starts to rattle violently. i have hasport hydro conversion for sohc. im not sure what speed it starts 2 rattle @ cause my speedo not hooked up but around 90mph.
i have heard of ppl breaking their windshield because of this. is there ne way 2 counteract this atleast a little?
1. Don't go 90 mph - this will be tough since you're an "adrenajunky"
2. Sounds like your windshield is loose somehow, check on that.
3. Maybe try a torque damper? Dunno...
4. ????
5. Profit.
6. World Domination.
7. Give mcvtec $ for his sabbatical.
Modified by mcvtec at 9:14 PM 9/20/2008
4. ????
5. Profit.
I have the same set-up on my track car and it regularly sees 120mph without vibration.
Did you change axles or anything else at the same time as you installed the mount kit?
yeah i've changed all kinds of stuff.. hopefully i can track down the source of the vibration.. hopefully its not da mounts. cause 90mph limit is not gonna cut it
IIRC you can use the stock mounts with the Hasport brackets.
Have you tried re-installing the stock mounts to see if it makes a difference?
dr_latino999
Mar 26, 2007 12:19 PM
rondigs
Jul 21, 2003 06:26 PM
