Civic Front end Bent. how to fix that
Old Sep 19, 2008 | 09:12 PM
vy3tnamezz's Avatar
Default Civic Front end Bent. how to fix that
i got this ek. its been hit in the front. it was fix but not as nice as i want it to be. it has gaps everywhere along the headlight. grill fender. i was wondering can i replace the front frame some how?? is it posible to take it apart?? or can a really good auto body shop fix it. the frame is slightly bent. but enough to cause gaps. some people say its not even that bad, but its really anoying to me.
how did this guy take his front frame off like that. cut it??
Old Sep 19, 2008 | 10:08 PM
bigkvn77's Avatar
Default Re: Civic Front end Bent. how to fix that (vy3tnamezz)
Well the front he took off is called the core support. It was removed by drilling out the spot welds. The trick is to not drill through both layers of metal. But rather just the top portion so the core support gives way. Any body shop should beable to replace it for you. Its pretty ez just takes time. They sell spotweld cutters. There are 2 types. You do also need to weld a new one back on. So if you dont have one available. Let the professionals do it.
Don't use this type, they are horrible and the teeth break off way too easily.
http://cgi.ebay.com/ebaymotors...31060
Get this type. Its the kind I use. Works much better then the one above.
http://cgi.ebay.com/Rotobroach...l1116
chad
Welding / Fabrication
Jun 22, 2010 05:24 PM
DC4cedInducted
Dec 10, 2005 10:13 PM
Eibach95Civic
May 27, 2003 07:05 AM
serious
Sep 12, 2002 01:01 PM
