taking off h22 butterflies what to do with the longer bolts?
Old Sep 19, 2008 | 03:44 PM
turboedsupe's Avatar
Default taking off h22 butterflies what to do with the longer bolts?
So i took off the bitterflies on my h22 intake now the bolts are too long obviously. so for the 2 bolts ill just get them shorter but what about the studs? Should i just take them out and use bolts? Or do i have to replace them with shorter studs?
Old Sep 20, 2008 | 08:36 AM
LA_HONDAS's Avatar
Default Re: taking off h22 butterflies what to do with the longer bolts? (turboedsupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboedsupe &raquo;</TD></TR><TR><TD CLASS="quote">So i took off the bitterflies on my h22 intake now the bolts are too long obviously. so for the 2 bolts ill just get them shorter but what about the studs? Should i just take them out and use bolts? Or do i have to replace them with shorter studs?</TD></TR></TABLE>
Old Sep 20, 2008 | 09:32 PM
Swipe'd's Avatar
Default Re: taking off h22 butterflies what to do with the longer bolts? (LA_HONDAS)
when i removed my butterflies i just took off the throttle plates, and left that spacer in there for the extra volume. just get someone to weld up the two small holes from the bar that goes through which holds the butterflies.
Marcpb443
Oct 2, 2006 02:12 PM
