Brake Pedal LOW
This is ok an 1995 Accord LX Sedan w/o abs and rear drums. The car creeps forward and lights and the pedal will drop down. THe pedal is always low with the car on or off. After taking a look at itive bleed the brakes, checked for leaks, checked brake fluid level, and done the tests shown in the helms. I ended up changing my master cylinder the pedal feel firmer, doesnt sink and the car wont creep forward anymore. However the pedal is still low but only with the car on. When the car is off it will be perfectly fine. The car seems to brake fine also, just a low pedal.
i don't know what u mean by low. I would check and bleed everything again, check the vacuum line. did you bench bleed the master cylinder? maybe for some reason you got a similar master cylinder with a different amount of piston travel.
atmdc
21
Apr 11, 2007 07:06 AM
JZA70
Nov 14, 2006 11:16 AM
