Bought a CRX with EK front hubs...positive camber issue
Old Sep 19, 2008 | 02:35 PM
wakaranai's Avatar
Default Bought a CRX with EK front hubs...positive camber issue
The previous owner installed EK hubs and now the camber is positive up front. I'd say it is about +1 deg. Can I correct this with a camber kit or do I have to go back to DA/EF hubs?
Thanks in advance.
Old Sep 19, 2008 | 02:45 PM
89hatcher's Avatar
i believe you can correct it with a camber kit. maybe if you lower it more the camber can be at zero.
Old Sep 19, 2008 | 03:55 PM
fireant's Avatar
Default Re: (89hatcher)
Or salvage some CRX hubs and craigslist the EK hubs.
Old Sep 19, 2008 | 05:30 PM
wakaranai's Avatar
Default Re: (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">Or salvage some CRX hubs and craigslist the EK hubs. </TD></TR></TABLE>
Yeah, that is what I was leaning towards. I might be lowering the car anyways and that way I can use the money that was going towards the camber kit for the alignment ant the EF/DA hubs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i believe you can correct it with a camber kit. maybe if you lower it more the camber can be at zero. </TD></TR></TABLE>
The car is already lowered 1.5" But, I might be lowering it more. The problem is that I am running 205/50/15's and they would definitely be rubbing at 0 camber.
Old Sep 19, 2008 | 08:20 PM
wakaranai's Avatar
Default Re: (wakaranai)
So...anyone have this issue before?
Old Sep 20, 2008 | 12:02 PM
hushypushy's Avatar
I still think it'll be cheaper and perhaps even a more effective solution to go back to EF hubs. Since you wanted a bit of negative camber anyway...
fbmbmx07
Apr 7, 2008 08:15 AM
Wazup
19
Mar 11, 2004 06:18 AM
igone916
Mar 11, 2003 02:55 PM
