JDM B16A2 in 93 Civic DX. ECU Wire problem PLEASE READ
Old Jul 26, 2002 | 12:47 AM
Metal_SOL's Avatar
Default JDM B16A2 in 93 Civic DX. ECU Wire problem PLEASE READ
I just did an engine swap with a JDM B16A2 in my 93 Civic DX, I use all mine stock harness and add couple wire for the Vtec, and knock sensor. But i just notice that on my harness to the ECU is different than what i found on Hybrid.com. i'm missing the wire A12 (Fan output) and D10 (D10 GRN/RED ELD electric load detector ) D16 (WHT/YEL VREF VREF). I use the stock harness which is from 93 DX Civic. So can u guys tell me what are those wire for? and do i need it or what?
P.S i paste the OBD1 P30 chart here so u can see it.
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A4 ORN/WHT VTS VTEC solenoid
A5 LT BLU INJ3 INJ3
A6 ORN/BLK PO2SHTC O2 sensor (heating element)
A7 GRN/YEL FLR1 fuel pump
A8 (empty)
A9 GRN/WHT IACV IAC valve
A10 (empty)
A11 (empty)
A12 YEL/GRN FANC Fan Output
A13 GRN/ORN MIL MIL (check engine light)
A14 (empty)
A15 BLK/RED ACC (a/c compressor clutch)
A16 WHT/YEL ALT C alternator
A17
A18 (empty)
A19 (a/t trans only)
A20 RED PCS EVAP purge control solenoid
A21 RED/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
A25 YEL/BLK IGP2 to main relay and to gound for o
A26 BRN/BLK LG1 gound
B1 YEL/BLK IGP2 to pin A25
B2 BRN/BLK LG2 ground to shields for CYP & TDC
B3 (a/t trans only)
B4 (a/t trans only)
B5 BLU/RED ACS a/c switch
B6 (empty)
B7 (a/t trans only)
B8 BRN/RED PSPSW PSP switch
B9 BLU/WHT clutch interlock switch
B10 YEL/BLU VSS vehicle speed sensor
B11 ORN CYP P CYP -P
B12 WHT CYP M CYP -M
B13 ORN/BLU TDC P TDC -P
B14 WHT/BLU TDC M TDC -M
B15 BLU/GRN CKP P CKP -P
B16 BLU/YEL CKP M CKP -M
D1 WHT/BLU VBU Back Up Power
D2 GRN/WHT BKSW brake switch
D3 KS Knock Sensor
D4 BRN SCS service check connector
D5 (empty)
D6 ORN/BLU VTM VTEC pressure switch
D7 LT BLU TXD/RXD (data link connector)
D8 (empty)
D9 PNK ALT F alternator
D11 RED/BLU TPS TPS Signal
D12 YEL/GRN
D13 RED/WHT ECT ECT sensor
D14 WHT PHO2S O2 sensor
D15 RED/WHT IAT IAT sensor
D16 WHT/YEL VREF VREF
D17 WHT MAP Map Signal
D18 (a/t trans only)
D19 YEL/GRN VCC1 MAP 5V
D20 YEL/WHT VCC2 TPS 5V
D21 GRN/BLU SG1 MAP GND
D22 GRN/WHT SG2 TPS GND
hardtarget2
30
Dec 20, 2015 10:39 AM
Grim_6_6_6_
Jul 2, 2013 12:53 PM
shawn_crx
Oct 22, 2009 07:38 PM
civicracer1993
12
Dec 24, 2003 06:11 AM
Metal_SOL
Jul 26, 2002 01:51 AM
