Problems... Oh the problems
Old Sep 19, 2008 | 09:08 AM
archipeep's Avatar
Default Problems... Oh the problems
Hello everyone,
My 91 Civic, 1.5L recently died on the freeway, and after troubleshooting we decided that the timing belt had gone bad and that a valve job was most likely needed - which it was needed and now my compression is MUCH better. We did this work, and got it all back together, but the car won't start still. I'm getting electricity to the plugs, but getting no combustion. In fact, after removing the plugs, they are clean and there is no sign of fuel, which leads me to believe that no fuel is getting into the cylinders. I've poured fuel directly into the intake manifold (though the fuel pump seems to be working fine), and still no combustion. The intake does have suction when cranking the engine over...
I'm lost as to what could be happening, or not happening for that matter. If you have any ideas, I would appreciate hearing them. Thank you for your help. I hope I can return the favor in the future.
Old Sep 19, 2008 | 09:11 AM
scottmog's Avatar
Default Re: Problems... Oh the problems (archipeep)
pm'd
Old Sep 19, 2008 | 09:42 AM
JustAnotherRex's Avatar
Timing off 180 degrees?
Firing order correct?
Test the fuel pump to be sure it is working?
Test your injectors?
Old Sep 19, 2008 | 10:01 AM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Re: (JustAnotherRex)
Check your ground wires, mine was loose on the thermostat and the fuel pump wasn't working...
Old Sep 19, 2008 | 12:15 PM
archipeep's Avatar
Default Re: (Dc4iNtEgRa)
Timings fine, double and triple checked it. Distributer has offset alignment so can only be put back on one way. Fuel pump works fine, plenty of pressure. Injectors tested fine. Keep in mind that we even poured fuel directly into the intake to test. Still didn't work. Watched the fuel injectors spit out fuel while cranking. Still didn't fire.
Any other thoughts?
Old Oct 4, 2008 | 04:40 PM
archipeep's Avatar
Anybody?
I've also checked the voltage to the injectors with the ignition on, and it wasn't getting enough volts, if any. Checked the Main Relay, looks fine. Not even hairline cracks in the soldering. Out of curiousity I checked the voltage to the MAP sensor with the ignition on, and no voltage there as well. Could it be a defective ECU?
Desperately looking for some help...
Old Oct 4, 2008 | 04:43 PM
archipeep's Avatar
Mog, got your PM later on in the day... Thanks for trying to help, but as I do not know you, I feel that calling a little uncomfortable calling. Please post if you have any answers. Thank you...
jerryscherry
Mar 18, 2010 12:13 AM
tfeagley
Feb 16, 2009 01:57 PM
H22TurboNos
Nov 5, 2007 03:16 AM
blaxican05
Sep 29, 2006 08:23 PM
ericlee303
Apr 28, 2004 03:31 PM
