port and polish
Old Sep 19, 2008 | 08:21 AM
tensecpass's Avatar
Default port and polish
i have a d16y7 yes i know its not a good all motor car. but im still gonna play with it...so my question is should i have the head ported and polished? anything else i should do while they are doing that? anyone know where i can get hi compression pistions for a y7?
Old Sep 19, 2008 | 09:22 AM
garados's Avatar
Default Re: port and polish (tensecpass)
definitely get the valve seats reworked. If you can get larger valves, put them in and have the valve seats opened up to accommodate the valves. If you just have the stock valves, have the seats opened up as far as they can go so they contact the valve as far out as possible. Leave some meat in there for valve-to-head heat transfer. Regardless, a multi-angle valve job will help immensely as far as flow into the cylinders is concerned. I'm sure others will chime in on other things to do as well as agree/disagree on what I've said.
LSTEG96
Sep 8, 2007 05:08 PM
RTW DC2R
Mar 27, 2006 07:20 PM
Vadian
Jul 21, 2003 02:09 PM
boomslang
Sep 17, 2002 07:23 AM
