No injector pulse!!!
Alright, 90 Civic, B20B, running obd0 will not get fire to the injectors. Good Spark, Good Fuel Pressure, but injectors no worky! I purchased a noid light today and i am getting no voltage whatsoever at the injectors. Double checked all my MPFI wiring and it is correct. Tried a diff ECU and same thing. I know the Main Relay controls the fuel pump but would it also make the injectors pulse????? Any help would be greatly appreciated.
i was told that if it clicks 3 times before crank up (1. when the key goes to acc and CEL comes on 2. When CEL goes off before cranking 3. Crank up. It does that and i hear the fuel pump buzzing.
black0hatch
Sep 25, 2014 02:41 AM
