jdm final drive?
Old Jul 25, 2002 | 10:23 PM
Turbo R's Avatar
Default jdm final drive?
what benefits to you achieve from it at th drag strip or none.?
Old Jul 25, 2002 | 10:24 PM
type r 01-1063's Avatar
Default Re: jdm final drive? (JDMan)
umm.. do a search
Old Jul 25, 2002 | 10:27 PM
OutLaw MR's Avatar
13.9 on street tires!?WTF?!
Old Jul 25, 2002 | 10:44 PM
Turbo R's Avatar
Default Re: jdm final drive? (OutLawR)
i tried a search. nothing
Old Jul 25, 2002 | 10:50 PM
Let me help you out...
https://honda-tech.com/zerothread?id=204825
https://honda-tech.com/zerothread?id=181665
https://honda-tech.com/zerothread?id=181472
https://honda-tech.com/zerothread?id=170310
[Modified by type r 01-1063, 7:50 AM 7/26/2002]
Old Jul 25, 2002 | 10:51 PM
Austin's Avatar
If you install some Nitto NT-555R(drag radial) tires you will be running a gear ratio that is effectively a JDM final drive...hence the reason that the Nitto drag radials work so well, it's all in the marketing. This applies for using the 205-45/15 tires from the 195-55/15. Now if you already have a JDM FD and install the tires you will be running an effective final drive that is higher than the ATS 4.929...I've been doing a little research lately .
Austin
Old Jul 25, 2002 | 10:58 PM
Turbo R's Avatar
Default Re: jdm final drive? (type r 01-1063)
thanks
j4dlsd
Nov 3, 2004 08:46 PM
4doortypeR
May 12, 2004 09:59 PM
whitenameseboi
Apr 28, 2004 04:41 AM
vtecjunkie
Jan 24, 2002 10:58 PM
TypeR 599
Oct 28, 2001 11:26 AM
