Ignition issues on 94 hatch
Hey everyone,
I have posted other posts prior, but i'm still having an ignition issue with my car. I worked on it all night, and found that a relay under my driverside kick pannel was clicking rapidly, Relay RZ-0132. I believe this is the main relay. Could this be my issue. I am getting power to the computer and to the Distributor. But it still won't start.
PLEASE help.
(I can't reply to posts because i am new to honda-tech and it only allows me to add 5 a day.) Thanks
PLEASE help.
first make sure your battery is good then check if the engine is getting spark change the spark plugs just in case check fuel if the pump is working then check ecu for codes then check fuses if all of this works change the ecu or main relay
Hey, yeah i live right in mendham. I Did new spark plugs and today i bought a new distributor. So i'm down to the fuel issue. Thanks for the offer! but I think i narrowed it down. But i'll definately take you up on it if you up to the job!
(had two mechanics over, they are clueless, replaced the main relay today and now the fuel pump isn't priming,
well let me know how you make out....i wont charge you or nothin...if im free and have a ride(in a chair from a bad car accident but i CAN still work on a car trust me) i'll come down...im not in a chair permanetly just about 5 more weeks but i'll take the energy to help a fellow honda tech member...just keep me posted
Thanks man! yeah i might be taking you up on it!!! lol (haven't been on here cause i've been working on this danm car every free chance i get.) But now the car has a new fuel pump, new distributor, and a new main relay. The car STILL won't start.
I am clueless. I'm gonna check the computer next. It has a P28 in it, not chipped. But still, i'm totally clueless as to why the car would just **** out on me.... Did some reseach, I'm gonna look into the timing and make sure thats all up to par, and also check the valve lash. My buddy suggested that i look at it. He's a honda expert, so he'll be over on sunday. But if i need a hand, i will definately hit you up. And dude, i work in riverdale!!!! My boy lives in wayne. Charles Punta, He has a sick DSM. Name sound familiar????
Ok, now when you say it won't start, do you mean it won't turn over?, or turns over but won't run? if won't turn over, after everyting else fails check the clutch switch and see if it's engaging.
Got her all going now. It was a wire issue with the Vtec controler. But Russ, i work at the BJ's. Right off of 23. I'm up there all the time! you need to get better and then we can go for a cruise! hit me up sometime.
my email is chazfehn@yahoo.com. So send me a message with your number, we can meet up or somethin.
Back to the SAME problem. I drove the car for about a week or two, ran great. Brought it to my buddies house who also has a hatch. I timed it took her for a spin. Got back, DIED!!! Come over the next morning, fired right up. Get her home, i go out again, and it died on the way home. Got towed home, fired right up again this morning!!! I just went to go in the car to pick up my woman, and now it won't start again!!! I am soooo clueless.
go back to the basics, spark, fuel, compression, and power. and recheck your vtec controller wiring, iunno how it's wired, but if it caused your first break down, this could be the reason why it's not starting again.
i had a friend who had to same problem only thing when driving the problem cause the car to shut down but it would start right back up again and you know what we got to find out the v-tec controller had dry solder after resoldering the joints up to this day he is driving the car not having that problem again.so my money is on that controller trust me give it a thorough check meaning unscrew it and check the components and have a solder iron in case.
vccasanova
Mar 24, 2013 11:34 PM
panda teggy
11
Jul 6, 2011 01:18 PM
tuckandduck
Nov 11, 2008 09:39 PM
