D16y7 to D16z6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGhatchguy »</TD></TR><TR><TD CLASS="quote">no you need the distributor for that head or there will be no vtec..</TD></TR></TABLE>
The distributor doesnt control vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93accordsleeper »</TD></TR><TR><TD CLASS="quote">Can I use my D16y7 distributor on a D16z6 head? trying to do the Mini Me swap in my 97 LX wit a D16z6 head</TD></TR></TABLE>
yes you can. I have a y7/z6 using the y7 dizzy. However it doesnt bolt right up. I had to modify the tabs for the mounting bolts on the diz housing. Running a p2p and vtec engages fine.
You could get a conversion harness or repin the z6 into the y7 plug. Or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub »</TD></TR><TR><TD CLASS="quote"> modify the tabs for the mounting bolts on the y7 diz housing.</TD></TR></TABLE>
Or better still swap the guts out of the Y7 distributor into the Z6 case. I've done this between D15B7 and D16Z6 distributors before. I'm 99.9% sure that everything inside the OBD2A distributor is the same as the OBD1 versions.
Nail its head to a tree, cut all the way around its neck, grab a hold and pull down, there u go skinned cat! But swapping the guts sounds good if that works, thanks for the info guys
JJDd16z6
Sep 21, 2011 01:44 PM
VnZo
Dec 25, 2009 01:27 PM
mizzoEG
Nov 13, 2007 05:06 PM
thenick
Sep 25, 2004 07:20 AM
-[95cxhatch]-
Dec 16, 2003 06:46 PM
compatible, d16y7, d16z6, distribitor, distributor, guts, head, httphtarchiveorgshowthreadphpt2389964, mini, motor, swap, vtec, wit, y7, z6
