how hard is it to...
okay how hard is it to change the alternator oh a cbr f4i... i just found out today that it doesnt charge my battery and doent hold charge. at first i tought it was because i didnt use my bike everyday...
If you haven;t already... test the charging system:
http://cbrworld.net/forums/thread/140473.aspx
That tutorial will work for your bike
New alternator (stator) will be pricey. New rectifier will run around $100. Get the aftermarket unit if you can, it's a much more reliable piece than the OEM.
Check http://www.ronayers.com for OEM parts
when did you last replace the battery?
batteries die very quickly on bikes so there is a good chance you might just need a new one
if youre unsure about the condition of the battery, take it out and go to a dealer. They can test it right in front of you and tell you the batteries current health with a portable tester tool
It might just need a charge. Take the battery to autozone and they will test it and charge it for free.
If the bike has been sitting for a month or so the battery likely just drained and needs a recharge.
