relay help
i have a 91 crx hf and it runs good and everything dose not cut out but some times i go to start it and the fule pump will not come on i and ill try it some more and it will start and be fine but some time is will just die right after you start it would it be the fuel pump relay or what
Resolder the insides of the main relay located near the hood latch opener in the driver side. If you don't know what I mean. Go to tegger.com. From my experience so far the main relay seem to be the cause of all my non starts.
I wouldn't be telling you unless I tried it myself. I resoldered my main relay and carry one in my glove box as a spare. You never know. Go here: http://www.marklamond.co.uk/te...y.htm
I couldn't get a clear understanding due to your grammar. But if your starter does not crank and you can't hear your fuel pump. I would try the main relay fix. Do some searching on this website there are a lot of great info but you need to work for it.
good luck
good luck
Brand
21
Sep 8, 2022 09:39 AM
bigjefft
Apr 22, 2012 12:24 AM
AgentJam
Aug 15, 2004 03:07 PM
