dc booster into ef
Old Sep 17, 2008 | 03:08 PM
xileap2's Avatar
Default dc booster into ef
Ok, I still can't seem to find a DA master cylinder and booster for disc conversion. This guy offered me his 1" cylinder and booster from a DC.
My question is will the booster work with a DA suspension?
Old Sep 17, 2008 | 03:16 PM
sleepingciv's Avatar
Default Re: dc booster into ef (xileap2)
i dont think ya need the da booster and master, you just need the portioning valve, and the rear stuff for the swap
but it will fit if ya want it
Old Sep 17, 2008 | 03:24 PM
xileap2's Avatar
Default Re: dc booster into ef (sleepingciv)
Should of been more specific .....im doind DA dis conversion all around...
Old Sep 17, 2008 | 03:27 PM
Well i would say if ya can get one i would use it, but i dont think ya will need for the swap. the ef's does look good with that booster though
Old Sep 17, 2008 | 03:32 PM
xileap2's Avatar
So your saying I can use the 96 dc mc/booster with the DA setup?
Old Sep 17, 2008 | 03:35 PM
is it non abs?
Old Sep 17, 2008 | 03:38 PM
xileap2's Avatar
Forgot to ask, but if its non-abs I may use it then right?
Old Sep 17, 2008 | 03:40 PM
dc
da
look the same as ef
ya only a non abs booster
but dont forget to get the proportioning valve
Old Sep 17, 2008 | 03:44 PM
xileap2's Avatar
DC looks huge...ok I ask him and he said it non abs...I know it bolts in, its just I wanted to make sure it'll work before getting it...
Old Sep 17, 2008 | 03:47 PM
ya it will work ya might have to bend the brakes lines some so they will screw in but ya good to go i think
Old Sep 17, 2008 | 03:55 PM
xileap2's Avatar
Yea, I have a 4040 prop valve already, just need a mc/booster... thanx for all the help sleepingciv
Old Sep 17, 2008 | 03:56 PM
no prob have fun
Old Sep 18, 2008 | 09:31 PM
dem0nk1d's Avatar
go with the Civic EX Sedan booster the lines will hook in perfectly. the dc port is on the other side of the unit. Also the EX is a 15/16 so your what a 1/16 short of an inch. Get the porp val from a 90-92 Integra. I'd buy the booster from autozone, and the master unit from NAPA 115bucks when i got mine. Booster was like 45-60 or something.
also note you can't use the civic cylndr with the integra booster the bolt pattern is reversed. i know for fact. done it...
Old Sep 19, 2008 | 05:27 AM
abnaasefmb's Avatar
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">go with the Civic EX Sedan booster the lines will hook in perfectly. the dc port is on the other side of the unit. Also the EX is a 15/16 so your what a 1/16 short of an inch. Get the porp val from a 90-92 Integra. I'd buy the booster from autozone, and the master unit from NAPA 115bucks when i got mine. Booster was like 45-60 or something.
X2 that's what i did.
Old Sep 19, 2008 | 06:55 AM
CRX Toad's Avatar
Any Integra or Civic booster will fit you just can't mix ABS with Non ABS parts and Civic with Integra.
An ABS will bolt on just fine I have one. You just have to change one fitting. It is easy.
Also there is a tag on the top of the booster that says what it is. I have provided that info below.
ABS = 290v
Non Abs = 260v
Civic = 205v, 190v
The ABS give you less brake pedal movement as it moves more fluid with less travel.
Old Sep 19, 2008 | 01:44 PM
xileap2's Avatar
I got both the mc/booster together non abs...so I'll slap those on after I order the s.s. Brakelines
Old Sep 19, 2008 | 01:50 PM
xileap2's Avatar
Default Re: dc booster into ef (CRX Toad)
Good info I'll check that out when I get home...1 more thing, on the 1" mc is there a DIY on how to flare the brakeline?
Old Sep 19, 2008 | 09:24 PM
sinepome's Avatar
for flaring you just need a flare tool. check autozone advance or maybe even walmart. pretty easy to use.
Old Sep 21, 2008 | 02:23 PM
xileap2's Avatar
Default Re: dc booster into ef (sinepome)
Ok, how would go upon getting a nut for the brakeline after flaring it? Thanx 4 the help.
Old Sep 21, 2008 | 06:44 PM
xileap2's Avatar
S*** I just read the tag and its 290v(abs) so the mc must be abs. Is there a way I can still use this set up for my DA suspension or would I need the non abs mc/booster?
Old Sep 22, 2008 | 05:08 AM
CRX Toad's Avatar
290v will bolt up just fine you just need to reflare one fitting...easy as pie.
When I say you can't mix abs with non abs. I mean you CANNOT mix ABS mc with Non ABS booster or vise versa.
Old Sep 22, 2008 | 05:51 AM
xileap2's Avatar
Okay sounds good. But how would I go upon ordering the fitting for the larger mc?
Old Sep 22, 2008 | 06:14 AM
CRX Toad's Avatar
Take the MC to auto parts store and let them know you need the bigger fitting for the back line. I typically cut them off the car but you are past that point now. You could probably got to Honda and get one too.
Old Sep 22, 2008 | 06:26 AM
xileap2's Avatar
I have both fittings on the mc. So I'll just go to autozone and ask for the fitting. So after I flare it it'll bolt right in to the brakeline? Thanx 4 the help
