Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Work XD-9's
Old Sep 17, 2008 | 01:40 PM
DavidHLX's Avatar
Default Work XD-9's
Will it fit with my 2007 honda civic sedan LX? If it doesn't what size would?
Wheel size 17 X 7.5 offset +42
Thanks in Advance
Old Sep 17, 2008 | 02:15 PM
brzrkr's Avatar
that size should fit fine.
Old Sep 17, 2008 | 04:45 PM
DavidHLX's Avatar
Default Re: (brzrkr)
also I got another questiong.... If i plan on lowering my car..(I'm new too this whole lowering thing)...so I was wondering if I can get the HFP Suspension Kit and use the Eibach Sportlines springs.. is that possible? how good is the ride? or should i just get the spring and 4 camber kits?
Thanks once again!
Old Sep 18, 2008 | 05:09 AM
Type X's Avatar
Default Re: (DavidHLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidHLX &raquo;</TD></TR><TR><TD CLASS="quote">also I got another questiong.... If i plan on lowering my car..(I'm new too this whole lowering thing)...so I was wondering if I can get the HFP Suspension Kit and use the Eibach Sportlines springs.. is that possible? how good is the ride? or should i just get the spring and 4 camber kits?
Thanks once again!</TD></TR></TABLE>
if you got the hfp suspension kit and eibach springs, you'd have an extra set of hfp springs and voided warranty on the shocks.
I'm sure the ride would be good for a while but ultimately you'd be driving on something that wasn't designed for that much of a drop.
The HFP is so miniscule that you dont need a camber adjustment
however with the eibachs you would.
Old Sep 18, 2008 | 08:35 AM
DavidHLX's Avatar
Default Re: (Type X)
Would I need a rear camber kit or a front camber kit? Since I drive a Honda Civic LX does it void warranty if I got the HFP suspension kit?
Old Sep 18, 2008 | 01:22 PM
brzrkr's Avatar
If you put on just the HFP suspension kit, you wont need a camber kit, and you should have warranty, i think 1 year if you install yourself, and 3 years if a dealer installs. correct me if im wrong
Old Sep 18, 2008 | 01:33 PM
Zeusone's Avatar
no warranty on self installs. you will need an alignement after due to the disassembly of the suspension.
Old Sep 19, 2008 | 03:08 PM
DavidHLX's Avatar
So if I were to get the eibach sportline spring I would need the rear camber kit or front camber kit or mabe all 4 camber kits? Sorry for the stupid questions.. IMA noob Also can I put a sway bar and a camber kit?
Old Sep 20, 2008 | 10:36 PM
burnout8488's Avatar
Default Re: (Zeusone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeusone &raquo;</TD></TR><TR><TD CLASS="quote">no warranty on self installs. you will need an alignement after due to the disassembly of the suspension.</TD></TR></TABLE>
Wrong wrong wrong wrong wrong.
You have a warranty on everything regardless of who installs it. Warranty coverage is determined depending on whether or not the lowering springs caused the strut to blow. Since there is hardly any way to tell whether you hit a huge bump and blew the strut, or if the lowering spring blew it, chances are the dealer would blame the spring.
Klimentiy
11
Dec 18, 2010 03:06 PM
travisallenn
Suspension & Brakes
Nov 3, 2006 02:19 PM
meektoo
Oct 4, 2005 04:55 PM
yugolude
Sep 2, 2004 03:19 AM
Paranoid Android
Nov 27, 2002 06:39 PM
