stock rim size on 2000 ex? looking to upgrade to 15 inch, need info to start looking..
Old Sep 17, 2008 | 01:25 PM
EJ8_Enthusiast's Avatar
Default stock "bolt pattern" on 2000 ex? looking to upgrade to 15 inch, need info to start looking..
I meant bolt pattern, not rim size, sorry.
I checked the manual, searched, went to tire-rack.com and cant find what I am looking for.
its not for performance, I just don't care for the tiny 14 inch toy wheels that are on it now.
I just need whatever info is necessary to make sure the rims I buy will fit.
Thanks.
edit: a decent place to buy them from too if you feel like mentioning one.
Modified by EJ8_Enthusiast at 2:36 PM 9/17/2008
Old Sep 17, 2008 | 01:32 PM
I guess what I am looking for is the bolt pattern, right?
4 x 100 ?
Old Sep 17, 2008 | 05:22 PM
jers99's Avatar
Default Re: (EJ8_Enthusiast)
Yeah that's the right size
4x100
Old Sep 17, 2008 | 05:53 PM
alphalanos's Avatar
Default Re: (jers99)
Tire Rack shows the bolt pattern. if you search wheels by vehicle then select a wheel it will show the bolt pattern. Make sure you get a decent set. Most wheels are really heavy. Some Rotas are lightweight and pretty subtle. Other wheels like BBS, SSR etc are very expensive.
Old Sep 17, 2008 | 06:01 PM
cool, thanks jers, alpha.
I hate to be a noob, but I am also impatient; they can go hand in hand when seeking information sometimes.
Old Sep 17, 2008 | 06:19 PM
Unit44justin's Avatar
http://www.jlbmotorsports.com
They have the best prices on rotas and are also a sponsor on here I always liked the Jmags and the Jspecials
Old Sep 17, 2008 | 06:33 PM
trying to stay as close to $300 as possible.. I will also need to put some rubber on them.
got a shitty cold snowy Michigan winter coming up.. maybe I should wait until Spring...
Old Sep 17, 2008 | 06:46 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8_Enthusiast &raquo;</TD></TR><TR><TD CLASS="quote">trying to stay as close to $300 as possible.. I will also need to put some rubber on them.</TD></TR></TABLE>
You may need to shop used. Rota is generally the first choice for budget minded Honda wheel purchases, and all of their stuff is at or over the $400 mark without tires.
I bought my Mini Cooper wheels used with "almost" brand new tires for $550 shipped. I've seen used OEM Honda wheel sets go for as low as $300 with usable (but not "good" per se) tires. Figure Rotas and Konigs to fall somewhere between those two on the used market.
Old Sep 17, 2008 | 07:02 PM
right on.
It seems 16'' seems to be a more common size than 15''.. is this preferable for some reason?
Old Sep 17, 2008 | 07:28 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8_Enthusiast &raquo;</TD></TR><TR><TD CLASS="quote">It seems 16'' seems to be a more common size than 15''.. is this preferable for some reason?</TD></TR></TABLE>
It depends. A lot of people prefer 16's because they fill out the wheel well more than 15's. Most of the hard core performance minded enthusiasts stay with 15's as they're usually lighter and less expensive while still having outstanding tire options (225/45/15 FTW).
Arolife
Honda Civic (2001 - 2005)
Apr 25, 2017 08:22 PM
comma
May 26, 2006 06:17 AM
csmsi311
Apr 28, 2004 07:36 AM
EF-Pimp
Nov 14, 2003 08:19 AM
