Dry Sump B series?
Old Jul 25, 2002 | 07:39 PM
EG6-SiR's Avatar
New User
Default Dry Sump B series?
Anyone had any results with dry sump setups on b series motors? What parts did you use? Dyno charts perhaps?
Old Jul 25, 2002 | 09:46 PM
Pelican's Avatar
Default Re: Dry Sump B series? (EG6-SiR)
Didn't Moroso just come out with a dry sump system for the B's? it was in SCC
But I don't think you're going to get like a noticeable HP/torque jump with a dry sump, unless you have some serious windage going on.
I like the idea because you can have less trouble with the oil return line from the turbo. I mean you can literally push the oil in and suck it back out with the extrnal pump. And of course, remote cooling/filtering would be a lot easier. Oh and what about taps for Turbos/LSVTEC/CRVTEC setups. Hell, it might be pretty advantageous. I still stick to the opinion that it won't increase HP, but it just might ease a few headaches.
Old Jul 26, 2002 | 12:43 AM
kinesistech's Avatar
Default Re: Dry Sump B series? (Pelican)
Itll probabaly: cost more than its worth unless your car sees the track every weekend, wont give any more power and may drain some since its run by a belt or chain. You'll still have the stock pump too. You'll need a scavange pump right.
It may relieve a headache or 2 but its sure to create another 4 or 5.
Old Jul 26, 2002 | 09:28 PM
EG6-SiR's Avatar
New User
Default Re: Dry Sump B series? (kinesistech)
I'm considering this for a drag motor but locating suitable parts for dry sump setup appears to be a problem...
Reducing the work the crank has to do should gain some numbers at least... Milking maximum numbers from limited displacement is as much an issue as traction will be :>
Thanks for the feedback anyway folks
DCbb6
Feb 25, 2005 06:31 PM
joshwhe
Jan 28, 2003 08:13 PM
