broken fuel pump "I THINK"
Old Sep 16, 2008 | 08:18 PM
aceboog3x's Avatar
Default broken fuel pump "I THINK"
i jus recently swapped my harness in my 97 dx hatch, cuz i did a 97 gsr swap. i put a harness from a 96-98 ex; and now everything is plugged in and now the car wont start. it was starting b4 i changed the harness wit the stock ecu, but now wit the gsr ecu; nothin! its getting spark, all the grounds are good,battery is new, and i jus put a new tps, and iacv. Any help on why its not starting???????
Old Sep 16, 2008 | 08:35 PM
twinksack's Avatar
* B A N N E D *
Default Re: broken fuel pump "I THINK" (aceboog3x)
have you checked for fuel
Old Sep 17, 2008 | 05:57 AM
aceboog3x's Avatar
Default Re: broken fuel pump "I THINK" (twinksack)
i put gas in it yesterday and still the same thing. i really cant tell how much gas i have in it cuz my gas gage is broke.
Old Sep 17, 2008 | 06:59 AM
Hanmin's Avatar
maybe you didn't plug in your injectors??? are you throwing a code after you keep attempting to start it??? Iunno if ek's have it but I know gsr harness's have it. But on the driver side of the tower, there should be 3 plugs(I think) and then 1 of the 3 plugs should have like a blockoff plate. This is for the injectors, make sure that plate is there. without it your injectors wont work.
Old Sep 17, 2008 | 09:05 AM
twinksack's Avatar
* B A N N E D *
Default Re: (Hanmin)
have you checked to see if gas is getting to the fuel rail
Old Sep 17, 2008 | 11:53 AM
aceboog3x's Avatar
Default Re: (twinksack)
the injectors are plugged in. and its crazy cuz it only throws a code wen te stock computer is in, but wen i put the gsr ecu in then it doesnt throw a code. its calling for a iacv wit the old ecu. but i jus replaced that brand new. idk.
Old Sep 17, 2008 | 11:57 AM
aceboog3x's Avatar
Default Re: (aceboog3x)
(have you checked to see if gas is getting to the fuel rail )
idk how. the only thing the guy did was pour some gas in2 the throttle body-manifold and the car started a lil then turned right off. it started hard 2, i didnt like the sound at all
Old Sep 17, 2008 | 11:58 AM
Hanmin's Avatar
are you 100% sure its getting spark fuel and compression? if it starts with another ecu and not with the gsr ecu, maybe the problem is in the ecu???
Old Sep 17, 2008 | 02:34 PM
twinksack's Avatar
* B A N N E D *
it sounds like its the injectors
Old Sep 17, 2008 | 07:34 PM
civicjoe's Avatar
like everyone else said check for spark and fuel. When you turn the key to 'on' I THINK that you should be able to hear the fuel pump prime.
Old Sep 18, 2008 | 03:18 PM
aceboog3x's Avatar
Default Re: (civicjoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjoe &raquo;</TD></TR><TR><TD CLASS="quote">like everyone else said check for spark and fuel. When you turn the key to 'on' I THINK that you should be able to hear the fuel pump prime.</TD></TR></TABLE>
i was thinkin it was my fuel pump but some1 else told me it might be my injectors. but wen i do turn on my key i hear something turn on but it sounds like its coming from the front passenger side.
Old Sep 18, 2008 | 11:40 PM
civicjoe's Avatar
When you turn your car to 'on' why would the injectors fire? Besides the injectors make a click clicky sounds while the fuel pump is a hum sound
Old Sep 19, 2008 | 06:30 AM
aceboog3x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicjoe &raquo;</TD></TR><TR><TD CLASS="quote">When you turn your car to 'on' why would the injectors fire? Besides the injectors make a click clicky sounds while the fuel pump is a hum sound</TD></TR></TABLE>
idk wat either of the sounds like. never really listened for it. jus tellin u wat i hear now wen i turn the key. "correct me if im wrong," but my fuel pump is under my back seat behind me??? and if so; then i dont hear it turn on. and if dats da case wit it not turning on wat should i do?
Old Sep 19, 2008 | 07:07 AM
twinksack's Avatar
* B A N N E D *
its easy to check there is a bleeder screw on the fuel filter its a 10mm open it up have some one turn the car on and see if gas comes out if it does its not the fuel pump
Old Sep 19, 2008 | 09:52 AM
aceboog3x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinksack &raquo;</TD></TR><TR><TD CLASS="quote">its easy to check there is a bleeder screw on the fuel filter its a 10mm open it up have some one turn the car on and see if gas comes out if it does its not the fuel pump</TD></TR></TABLE>
thanx let u kno wat happens. check it in a few
Timmay
Jun 12, 2007 05:50 AM
herbalist
Jan 23, 2006 04:18 PM
to_fuckin_slow
Jan 19, 2006 12:36 PM
93JDMHONDA
May 12, 2004 03:45 PM
