Ok to run fuel hose behind the brake lines?
Old Sep 16, 2008 | 06:51 PM
turboedsupe's Avatar
Default Ok to run fuel hose behind the brake lines?
I want to run my line like this then mount the inline filter on the firewall and will be help up by clamps. Is it safe??
Old Sep 16, 2008 | 09:36 PM
Mike@Highend Autosports's Avatar
Default Re: Ok to run fuel hose behind the brake lines? (turboedsupe)
I dont think it's a good idea because you motor move's back and forth from giving it gas or shifting and it could rip the line or damage brake line's.
Old Sep 17, 2008 | 09:07 AM
Default Re: Ok to run fuel hose behind the brake lines? (Mike@Highend Autosports)
What if i leave a little slack on the line from filter to rail?
Old Sep 17, 2008 | 08:37 PM
I would still suggest running it the factory way. That's my opinion
Old Sep 18, 2008 | 02:58 PM
Master23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike@Highend Autosports &raquo;</TD></TR><TR><TD CLASS="quote">I would still suggest running it the factory way. That's my opinion</TD></TR></TABLE>
Ditto for me. You dont want car to end up in flames if something goes wrong. Yes we care.
Old Sep 18, 2008 | 03:39 PM
bad ferio's Avatar
Default Re: Ok to run fuel hose behind the brake lines? (Master23)
keep it running through the bottom, below the heater hoses and then bring it back up to the motor
Old Sep 18, 2008 | 09:59 PM
Battle2.0Eg's Avatar
that black line is tough as nails maybe you should use 2 hoseclamps to be sure
Old Sep 18, 2008 | 10:11 PM
projectTeG's Avatar
okay lets see, ss braided line vs soft oem hard line? i see you brakes having trouble here in the near future. i would suggest running in under the heater hose and up to the rail. just so it stays out of the way of rubbing anything.
Old Sep 19, 2008 | 03:31 PM
00b18b's Avatar
Believe it or not, over some period of time that ss braided hose will rub right through that brake line if left like that. My opinion would be to get some rubber hose the same inner diameter as the outer diameter of that ss hose and cut 1inch and slip it over. Use a hose clamp and bolt it against the firewall.
double b from wv
May 14, 2009 04:40 PM
vtecspeed1320
Jun 12, 2007 02:07 PM
OMG naD16 lol
Nov 23, 2006 03:28 AM
bad-monkey
Aug 27, 2004 05:33 PM
