IACV TROUBLE HELP PLEASE!
Old Sep 16, 2008 | 05:50 PM
97coupecivic's Avatar
Default IACV TROUBLE HELP PLEASE!
My IACV was finished so I went to a wreckers to get a new one... Put it on and the car idles steady but when I give a little hit of gas the car dies a little then revs up.
The IACV was definetly the problem but here's my question..
The IACV I took of my 96-97 ITR motor looked like this
-----> http://www.superhonda.com/phot...2.JPG
And the one I put on looks like this
-----> http://i37.photobucket.com/alb...1.jpg
While those arent my 2 IACV look at hole beside the mesh and see the difference in diameter.. Is this causing my car to run bad?
THANKS.
Old Sep 16, 2008 | 05:52 PM
Comp97GSR's Avatar
Default Re: IACV TROUBLE HELP PLEASE! (97coupecivic)
Explain "dies a little then revs up". Kind of contradictory to me.
Old Sep 16, 2008 | 05:54 PM
Default Re: IACV TROUBLE HELP PLEASE! (Comp97GSR)
Sorry... I will give little tap of gas in neutral the car will dip below 650-700 rpm then proceed to go back up to idle.
Old Sep 17, 2008 | 04:23 PM
anyone??? any difference between the holes in both iacv?? will it make a difference how the car runs??
Old Sep 18, 2008 | 05:39 PM
Dang EG's Avatar
Are you running an aftermarket manifold because you should not be able to bolt them up perfectly unless I am wrong?...
If it was an issue, why not go out and find one that doesnt have a whole like that and try it out. Maybe a friend you can borrow from...
Old Sep 18, 2008 | 09:22 PM
FOMULA91's Avatar
Default Re: IACV TROUBLE HELP PLEASE! (Dang EG)
The 2 IACV you post has a different bolt pattern. That will not hold the IACV correctly and cause a leak. Do you have an ITR intake manifold? CUZ the 2nd IACV is the right bolt pattern for the ITR manifold.
The 1st picure allows you to use either IACV cuz it has the 2 different bolt pattern but the 2nd picture only allows you to use the chubby IACV.
Modified by FOMULA91 at 10:30 PM 9/18/2008
blue2006civic
Honda Civic (2006 - 2015)
Jun 17, 2015 06:13 PM
96 EK HATCH
Oct 5, 2011 12:32 PM
JasinC19
Dec 2, 2008 03:33 PM
uszcrx
19
Jun 19, 2003 04:27 AM
