00' Si or 00' SiR
Hey guys, I'm looking to buy either a 2000 Si or an SiR but I don't know which one to pick. I'm not going to be into any major racing, just a bit of horseplay with some friends, one owning an Acura RSX Type-S with only a K-Pro Chip added and an intake. As for any modding, I plan on only doing a few things, to name a few -ECU, Headers/Exhaust, Intake. Would I be able to keep up with his RSX with either Civic?
Thanks.
Thanks.
yea sorry not gonna happen. A stock b16 with just I/H/E and ecu wont be able to keep up with a type-s. you would need to step it up more to keep up. if you want a stock motor with just bolts on and ecu to keep up if not beat a type-s, then you need one of the monster of honda motors. The all mighty H22.
The Si - You have 0 Chance, unless his car dies or he stalls... or something..
The SiR - You will be able to hang with him, but you won't beat him...
since yur in brampton, canada, the civic SiR, is the CDM version of the USDM Si, only difference is it says SIR on the cluster, they come with same engine B16A2 and everything else
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batallic »</TD></TR><TR><TD CLASS="quote">since yur in brampton, canada, the civic SiR, is the CDM version of the USDM Si, only difference is it says SIR on the cluster, they come with same engine B16A2 and everything else</TD></TR></TABLE>
Correct, and the Si he's refering to is our version of the US EX coupe. G2 speed pretty much got it right. basically if you don't want to do an engine swap then the SiR is your best bet, but if you plan to do an engine swap and drop something like say a B18C1/C5 in there or an H22, K20 or whatever then the Si would make more sense as you aren't paying for an engine you aren't going to use.
We also get heated side mirrors, larger washer fluid tank and ABS...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpared01 »</TD></TR><TR><TD CLASS="quote">yea sorry not gonna happen. A stock b16 with just I/H/E and ecu wont be able to keep up with a type-s. you would need to step it up more to keep up. if you want a stock motor with just bolts on and ecu to keep up if not beat a type-s, then you need one of the monster of honda motors. The all mighty H22.
</TD></TR></TABLE>Blah. I have pulled away from a couple with just bolt on's in my 2000 Si.It was closer than i would have liked,but its not like a strong,well driven Si can not hang. FYI I ran 14.50's at 96ish.
Thanks guys. Since I'm on a budget, the H22 would be my pick for an engine swap but where could I buy from?
Would http://www.jdm-online.com or http://www.japanmotorimport.com be of any use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin »</TD></TR><TR><TD CLASS="quote">gsr swapped eg hatch, I eat type s all day=]. with passenger, </TD></TR></TABLE>
yes sirrrrrrrr.
yes sirrrrrrrr.
blah what ? you have to look at the numbers. im sorry but a 1.6 b16 with just 158hp w/ non lsd tranny vs 2.0 k20 w/ 200hp-210hp and a close ratio lsd tranny. yea i dont think so.
No Sales Forums
From: Reading the Chronicles and Blowin Trees in Virginia
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TonyEG 503 »</TD></TR><TR><TD CLASS="quote">SiR yo !</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpared01 »</TD></TR><TR><TD CLASS="quote">blah what ? you have to look at the numbers. im sorry but a 1.6 b16 with just 158hp w/ non lsd tranny vs 2.0 k20 w/ 200hp-210hp and a close ratio lsd tranny. yea i dont think so.
</TD></TR></TABLE>Sorry,but Im too old to make things up and post them on here.Ive had CLOSE RUNS,but like i said,there is NO REASON a STRONG,well maintained Si with a good driver can not pull an RSX.At the time i was making maybe 10whp less than a Type S,and probably weighed 300 lbs less...........Not only have I raced at least ten of those things,my EX had one as well that I drove quite often.stock,they are not all that.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TorquelessEM1 »</TD></TR><TR><TD CLASS="quote">Sorry,but Im too old to make things up and post them on here.Ive had CLOSE RUNS,but like i said,there is NO REASON a STRONG,well maintained Si with a good driver can not pull an RSX.At the time i was making maybe 10whp less than a Type S,and probably weighed 300 lbs less...........Not only have I raced at least ten of those things,my EX had one as well that I drove quite often.stock,they are not all that.....</TD></TR></TABLE>
Weight isn't everything...
Along with the RSX having more power... it also has a much better tranny...
Since your told old to make thing sup and post them on here.... you should no that weight isn't everything...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Weight is NOT everything,but it makes a HUGE DIFFERENCE....a bolt on 2000 Si( with a GOOD DRIVER) will and can run right with if not INCH OUT a STOCK Type S.Thats all I have been trying to say.My Ex had an 02 Type s,and id say she was an above average driver.We ran our cars hundreds of times.Id win about %80 of the time.Ive run at least 50 at the track,a handfull on the street, and countless others during HPDE sessions. Even my friends with EM1s,and I have many of those, have reported the same results.Its not like we recieved faster EM1's in Az than other states/countries did. lol
