Mid-Atlantic (Sales) VA, DC, and MD
parting out 93 ej1, plus extras.
Old Sep 16, 2008 | 10:46 AM
itrhopeful's Avatar
Default parting out 93 ej1, plus extras. not 56k friendly.
after much careful thought ive decided to part out my ej. the engine is prolly no good but most of the rest of the car is decent. also many spare parts-
2 sets of stock springs $20 for both
ek shocks $20
teg lcas (one of the bushings was ground to fit ek shocks) $20
2 obd1 distributors $40 each
iats $5 each
evap purge control solenoids $10 each (185 at the dealership!!!)
map sensors $5 each
used oem fuel injectors (2 sets, z6 and z1) $10 a set
fuel rail, lightly polished. 10
oem fpr 5
z6 throttle body 25
z1 throttle body no sensors 5
teg tb (not sure what motor) 25
intake manis - (2 z6(one gasket matched to fit teg tb), 1 z1) no sensors included 25 each
a couple o2 sensors
wrinkle painted vc 40
unpainted vc 25
ngk spark plug wires, used, a little dirty 15
and then theres the car, all im keeping is the cd player and the stuff i made for it. maybe the trans.
pics are forthcoming, spare parts tommorrow. if you need a pic off of the car just let me know.
some pics on my member garage
[big]<u>everything is OBO!!!!</u>[/big]
pm with offers or e-mail at russ_main@hotmail.com
Modified by itrhopeful at 4:25 PM 9/18/2008
Modified by itrhopeful at 11:08 PM 9/23/2008
Old Sep 16, 2008 | 02:38 PM
itrhopeful's Avatar
Default Re: parting out 93 ej1, plus extras. (itrhopeful)
more pics, more stuff. some of this id already mentioned, some is new.
2 wheel covers, one in good condition, the other not so much
unpainted vc, some sensors, evap pcs, and injectors (1 set z6 1set z1, i'll be able to tell them apart when i get the ones that are in the car out. one of them is missing the screen)
z6 im, bare, completely
z1 im, no sensors on tb.
obd1 dizzy, d-series
z6/z1 fuel rail with fpr
clutch covers
b7 2 belt crank pulley (alt/ac), slight dent on outer ring, should file/sand out easily.
idle air control
vtec solenoids (one missing connector)
srry for the pic quality, they're mostly just to give an idea of whats here. if you need more info just let me know i'll be happy to help. thank you
Old Sep 16, 2008 | 04:46 PM
itrhopeful's Avatar
bump
Old Sep 16, 2008 | 05:07 PM
Ya Digg's Avatar
Are you selling the complete z6 minus the tranny?
Old Sep 16, 2008 | 08:18 PM
itrhopeful's Avatar
Default Re: parting out 93 ej1, plus extras. (Ya Digg)
its got a wicked knock and doesnt run, thats y i say its prolly no good. but if you want it still...
Old Sep 16, 2008 | 09:15 PM
itrhopeful's Avatar
bump before bed
Old Sep 17, 2008 | 02:30 AM
gen2fanatic's Avatar
PMed
Old Sep 18, 2008 | 09:52 AM
itrhopeful's Avatar
replied
Old Sep 18, 2008 | 11:46 AM
itrhopeful's Avatar
more stuff pulled off the car:
alternator
another obd1 dizzy
ngk blue plug wires (the ones just above oem spec)
headlights (drivers side is missing a tab)
side marker lights (pass side lens came unglued)
skunk2 front strut tower bar
a third vtec sol.
another evap pcs
z6 im, gasket matched to accept teg, tb.
z6 tb
z6 fuel rail and injectors.
pics later. stuff is gonna start going on ebay in the next week so if you need something let me know while i still have it
Old Sep 18, 2008 | 12:27 PM
itrhopeful's Avatar
some prices added- really need to move this stuff. local pickup. everything is negotiable.
stuff will start going out on ebay in the next week so dont miss it
Old Sep 18, 2008 | 08:09 PM
itrhopeful's Avatar
bump, more stuff tommorrow
Old Sep 19, 2008 | 05:43 PM
itrhopeful's Avatar
Default Re: (itrhopeful)
up
Old Sep 19, 2008 | 07:24 PM
itrhopeful's Avatar
cut myself at work, it hurts, bump
Old Sep 20, 2008 | 06:44 AM
itrhopeful's Avatar
morning bump-cluster is pending
Old Sep 20, 2008 | 03:54 PM
itrhopeful's Avatar
bump
Old Sep 20, 2008 | 08:13 PM
itrhopeful's Avatar
and again
Old Sep 21, 2008 | 02:27 PM
itrhopeful's Avatar
bump again
Old Sep 21, 2008 | 08:03 PM
itrhopeful's Avatar
Old Sep 22, 2008 | 11:11 AM
itrhopeful's Avatar
more stuff!!! you know you want it
virgin p28
power mirror switch
cruise control switch (from steering wheel)
sunroof/dimmer/cc(on/off) switch
defrost and blockoff plate
efi main relay- working!
hazard switch
Old Sep 22, 2008 | 07:44 PM
itrhopeful's Avatar
a couple people have asked about the shell, i just want to make sure you know it will be stripped clean (i might leave the windshield cause theyll be a pain to get out) and that the frame is bent. this is a shot of the front end , hopefully you can see where the headlights are not parallel to the groundand the front bumper is cocked o so slightly toward the drivers side
it does not seem to effect handling, ive driven with the car like this for several yrs now (@ roughly 20k miles a yr). ive found that people rarely notice it unless i mention it, but then again im not showin the car.
Old Sep 22, 2008 | 08:05 PM
XkjeldorX's Avatar
how much for the cluster? Manual right? Im located in central jersey
Old Sep 22, 2008 | 08:50 PM
itrhopeful's Avatar
Default Re: (XkjeldorX)
it is a manual, cluster is pending.
Old Sep 23, 2008 | 11:55 AM
itrhopeful's Avatar
more stuff.
trim from under steering wheel
bezel+oem clock
grey center console
battery tray, painted black
radiator, oem fan, reservoir
vss
Old Sep 23, 2008 | 07:19 PM
itrhopeful's Avatar
bump
Old Sep 24, 2008 | 12:05 PM
itrhopeful's Avatar
bump it
