fuel pump questions asap
Check the specs on both fuel pumps. If the pressure and gpm specs are the same you should be able to use stock. But seeing on how the LS is a mpfi It should maybe have higher pressure than a dpfi system.
spoon23_JDizM AkA SpOoN20
Feb 24, 2004 03:36 PM
