Fiber glass Duct Construction??
so i know what i want to build in my mind... pretty much think about a js racing eg/dc2 duct but i want to create one on a usdm 98-01 USDM integra front bumper...
so as far as the actual release agent gelcoat resin and laying out fiberglass goes i think i have a good handle on it...
What im stuck on is what would be the best way to make a plug (item that i lay the fiberlass on) for it? all i have to work with is a rectangular hole in the bumper (where the parking light goes) any ideas?
thanks in advance
thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen »</TD></TR><TR><TD CLASS="quote">carve it out of foam.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote">cardboard or polystyrene foam always works</TD></TR></TABLE>
is the foam a block or is it the mix and pour kind?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaxican05 »</TD></TR><TR><TD CLASS="quote">can i pick something like that up at like lowes/home depot? if not where can i find it</TD></TR></TABLE>
insulation foam spray IIRC its 13.99 a can at home depot, what you do is its in a can and you attach an included silicone see through hose, you pull the trigger and hold it wait it sets, its pretty hard.
i tried some when attached to mild steel 1/4 plate just to check it. pretty easy to work with. never id anyting with fberglass though
that foam stuff is pretty porous, go to your local arts and crafts store, and get the green floral foam. Shape it, paint it with aerosol latex house paint to protect the foam from the caustic resin, then lay your glass on it. drink.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DESTROYER »</TD></TR><TR><TD CLASS="quote">that foam stuff is pretty porous, go to your local arts and crafts store, and get the green floral foam. Shape it, paint it with aerosol latex house paint to protect the foam from the caustic resin, then lay your glass on it. drink.</TD></TR></TABLE>
i was actually looking at that stuff... it wouldnt be to soft?
sounds good! what worked best to cut just a regular knife? also do i need a gel coat? or is it possible to just use the release agent then put the resin on then cloth then resin
JDM Squad
Jan 30, 2007 10:25 AM
