used steel wool on red GT3's now they are dull.
Old Sep 16, 2008 | 09:17 AM
Dead CIVIC's Avatar
Veteran: Army
Default used steel wool on red GT3's now they are dull.
used a fine piece of steel whool to clean off som nasty overspray.
now the rim is dull, i'm wondering if buffing it will bring out the shine again...is so what kind compound should i use?
Old Sep 17, 2008 | 09:01 PM
Pandahatch's Avatar
The lip is clear coated, don't use aluminum polish. The steel wool is an abrasive that's why it's dull now. To get the shine back, you're gonna have to buff the wheels, either by hand or with a buffing pad/wheel. I use 3M products. Any type of polishing compound/glaze should work fine. You may to go over it with rubbing compound first to remove the haze/dullness and then the polishing compound to bring the shine back out like it was. Next time you get over spray, use some paint thinner, the wheel is coated with a clear that won't be effected by paint thinner.
Old Sep 19, 2008 | 08:40 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: (Pandahatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pandahatch &raquo;</TD></TR><TR><TD CLASS="quote">The lip is clear coated, don't use aluminum polish. The steel wool is an abrasive that's why it's dull now. To get the shine back, you're gonna have to buff the wheels, either by hand or with a buffing pad/wheel. I use 3M products. Any type of polishing compound/glaze should work fine. You may to go over it with rubbing compound first to remove the haze/dullness and then the polishing compound to bring the shine back out like it was. Next time you get over spray, use some paint thinner, the wheel is coated with a clear that won't be effected by paint thinner. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote">for the polished lip of the rim? maybe try mothers aluminum polish?</TD></TR></TABLE>
thanks guys...Pandahatch good info.
Old Sep 20, 2008 | 09:10 PM
switchjv's Avatar
Default Re: used steel wool on red GT3's now they are dull. (Dead CIVIC)
use a rubbing compound, that should poiish it.
Dead CIVIC
Sep 16, 2008 03:10 PM
RhdDc2R
Nov 1, 2006 10:37 PM
triple999
Oct 29, 2006 05:10 PM
@irborne
Welding / Fabrication
14
Jan 29, 2006 09:53 PM
The Poopsmith
Mar 19, 2003 08:56 AM
