water leaking from door speakers
Old Sep 16, 2008 | 08:49 AM
pxsx's Avatar
Default water leaking from door speakers
I washed my car yesterday and when I got back in a noticed some drips from both sides of the car, under the speakers in the doors. The speakers are already broken(now I know why ) but i was just wondering if anyone else has had this same problem???
what have you done to fix it?
Old Sep 16, 2008 | 12:15 PM
traxxasx's Avatar
Default Re: water leaking from door speakers (pxsx)
Have this sane problem, on my left speakers, dont know where its from either.
Old Sep 16, 2008 | 12:28 PM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: water leaking from door speakers (traxxasx)
It's so simple. Of course, on an un-original car, it may not be.
You want Honda OEM speakers and HOUSINGs. I am sure you can stuff non-OEM speakers into the housings, but the bottom line is that the housings actually have a gasket/seal that seals water out!
I pulled speakers out of an accord, and they were a perfect match (and the accord housings... pretty sure it was a 94-97 accord... could have been a 90-93 but pretty sure it was the latter). Bolted in right, no more leaks... from there.
On the passenger side, behind the door card, is plastic sheet that separates the door card from the skeleton/metal. water runs down your glass, and can then wick around and come in if the original plastic (thick/yellow sheet) is ripped or missing. It was basically gone from the passenger side. Take your door card off, you'll see. Walkthrough in the FAQ about door card removal, I think.
Old Sep 16, 2008 | 01:11 PM
h8tred's Avatar
From: Commonwealth my ass This is the communist state, VA, USA
Default Re: water leaking from door speakers (phoenix_iii)
The above posted could help, but it's not the cause of the issue. Mine didn't start doing it until I put a passenger side mirror on. So check your mirror gaskets.
Old Sep 16, 2008 | 02:11 PM
Dkahn18's Avatar
i always assumed it was because the drain off for the water was located around there, anyways its a very common issue in EF's, Do what i did, get waterproof speakers, if you dont know where to find some, a boat. Then again i live near and have friends who work at Cobalt Boat Factory, so mine were easy to aqcuire. Hope it helps.
Old Sep 17, 2008 | 08:20 AM
pxsx's Avatar
Default Re: water leaking from door speakers (Dkahn18)
yeah I was just going to buy some marine speakers, but that wouldnt fix the problem. water is still getting in. Ill check the mirror seals like you said.
Old Sep 17, 2008 | 08:28 AM
TheSauceSpot's Avatar
Having the same problem.. only after i was the car, not after rain tho. weird stuff.... im gonna try changing the mirror gaskets too now.
93egsi
Honda Accord 2016- 2017
Jul 31, 2018 09:23 AM
freshfahita
Aug 2, 2012 02:07 AM
anthonysmommy
Mar 18, 2008 09:37 PM
cinepro
Jul 11, 2007 07:08 PM
MCHAccordLX
Oct 19, 2006 06:04 AM
