need some wiring info on ODB2a ecu
Old Sep 16, 2008 | 01:12 AM
menthos's Avatar
Default need some wiring info on ODB2a ecu
i need to know where theese wires go:
pin A11 IGP1 - power source (yellow/black)
pin A24 IGP2 - power source (yellow/black)
pin D11 SG2 - sensor ground (green/black)
and should the be any voltage on the IGP1 and IGP2 when they cut?
Old Sep 16, 2008 | 03:36 AM
menthos's Avatar
Default Re: need some wiring info on ODB2a ecu (menthos)
finally i found a wiring diagram, but now i have another question...
according to the diagram, the IGP1+2 should be connected to the main relay at pin 3 and to the EACV/IACV and the fuel injectors...
but i can't figure out why i need to connect the fuel injectors and the EACV to the power source... the injectors already connects to the ECU on pin A1,A2,A3 and A4 and the EACV connects to the ECU on pin A12... so why does they need another +, shouldn't they just have ground on the yellow/black wire?
Note: this diagram is from ODB1 ECU so the pins doesn't exactly match
Old Sep 16, 2008 | 04:06 AM
GhostAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menthos &raquo;</TD></TR><TR><TD CLASS="quote">but i can't figure out why i need to connect the fuel injectors and the EACV to the power source... the injectors already connects to the ECU on pin A1,A2,A3 and A4 and the EACV connects to the ECU on pin A12... so why does they need another +, shouldn't they just have ground on the yellow/black wire?</TD></TR></TABLE>
The injector pins A1, A2, A3 & A4 going to the ECU are actually ground pins as well as pin A12 for the IACV. The ECU grounds these pins in order for the signal to pass through the injectors and the IACV.
Old Sep 16, 2008 | 04:18 AM
menthos's Avatar
Default Re: need some wiring info on ODB2a ecu (GhostAccord)
ahh alright
i thought they had ground all the time and a ecu controlled +
but as far as i see, the yellow/black wires from the injectors is connected to at grey which i think is a ground distribution plug.. a lot of black wires go into that plug too..?
Old Sep 16, 2008 | 04:27 AM
YEL/BLK wires shouldn't be going into a ground distribution block.
Is this a factory wire harness your working with or one that has been torn apart previously?
Old Sep 16, 2008 | 04:36 AM
menthos's Avatar
uhm i think the part im working on is factory wire, but all the wires that go from the engine to the the car has been apart i think...
i will try to take a picture of the plug..
Old Sep 16, 2008 | 04:47 AM
menthos's Avatar
ahh i see that the ground wires and the yellow/black wires are seperated... thought all the wires in the plug was connected together but it sperates at the middle:
Old Sep 16, 2008 | 05:01 AM
If you open the top of the distribution block you will be able to verify what wires are connected to each other. I couldn't remember if I had + & - mixed up in a dist box. I know that I don't have any mixed blocks anymore. I rewired mine so that all the positives play together and the negatives are all on the other side of the fence. Far far away from them.....lol
Old Sep 16, 2008 | 05:17 AM
menthos's Avatar
wonder why honda didn't do that cause i think its a bit confusing to have the + and - mixed in the same plugs
but for now i will let it stay like this...
i think i got the right wires now (atleast for the IGP1 and IGP2).. thanks for your help..
now i just need to find the SG2 sensor ground...
Old Sep 16, 2008 | 05:35 AM
menthos's Avatar
i see that the blue distribution plug also is divided in two..
so i guess the green/black wires should be ground and thats where the sensor ground SG2 needs to go and the black/yellow are + wires?
Old Sep 16, 2008 | 05:36 AM
you got it!
Old Sep 16, 2008 | 05:50 AM
menthos's Avatar
nice
what about pin 5 (black/yellow) from the main relay?
according to the diagram it only connect to the purge valve is that right?
Old Sep 16, 2008 | 06:16 AM
Yeah, I would go with what your diagram shows.
Old Sep 16, 2008 | 06:40 AM
menthos's Avatar
alright..
thanks for your help... now i hope all works...
Old Sep 16, 2008 | 07:26 AM
menthos's Avatar
argh my car stills runs like **** must be something else wrong...
when i turn the ignition on, the engine check light lights up like normal, but then it flash 2-3times before it goes off..
Old Sep 16, 2008 | 07:45 AM
Relic1's Avatar
what do you get when you pull the codes? (not the jumper, with a code scanner)
Old Sep 16, 2008 | 07:51 AM
menthos's Avatar
Default Re: (Relic1)
i don't have a code scanner
actually i don't know if that works on ODB1?
my ECU is is ODB with Ectune and then a ODB1-ODB2 harness.. my engine is ODB2a
Modified by menthos at 8:57 AM 9/16/2008
1999AZhatch
18
May 15, 2020 06:01 PM
99thwondah
13
Mar 20, 2015 01:40 PM
Stadler
Jan 14, 2010 06:32 PM
Tex Blackwell
Nov 24, 2004 07:35 AM
Yosshaa
Aug 7, 2003 09:30 AM
