A/C QUESTION? High pressure on low side? help me please
my a/c blows but not cold.
well i bought a can of refrigerant
for my 95 civic hatch that came with a/c.
the can says to turn the a/c on and check the pressure on the low side before i fill it up. the pressure was way over what it was suppossed to be
. the can stated that my problem was not related to low freon if the pressure was that high and that i should seek a mechanic.
does anyone have any idea what my problem could be based on those results. if there is anything i can do to get a better answer let me know.I HAVE SEARCHED THIS!
thanks
for my 95 civic hatch that came with a/c.the can says to turn the a/c on and check the pressure on the low side before i fill it up. the pressure was way over what it was suppossed to be
. the can stated that my problem was not related to low freon if the pressure was that high and that i should seek a mechanic.does anyone have any idea what my problem could be based on those results. if there is anything i can do to get a better answer let me know.I HAVE SEARCHED THIS!
thanks
Well, you need to also know what is on the low side. High on the low and low on the high is a bad compressor, if it's low on the low and high on the high, check orifice tube and such, could be blocked.
element_1one
11
Jun 28, 2014 11:03 AM
thiscivicuser
Feb 10, 2008 04:06 AM
