HELP REQUIRED/WILL PAY FOR SOMEONE TO FIX
damm if u want to do it the right way pull out tranny, replace casing. If u want to be ghetto JB weld is your friend. Next time, it is easier to add oil if you remove the speed sensor from the top. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC408 »</TD></TR><TR><TD CLASS="quote">If u want to be ghetto JB weld is your friend. Next time, it is easier to add oil if you remove the speed sensor from the top. Good luck</TD></TR></TABLE>
dont do it ghetto my freind, garentee it will bite you in the *** later on
KCUF_DB8
Sep 16, 2008 10:48 AM
