88 crx hf vs 92 civic vx
Old Sep 15, 2008 | 09:00 PM
guysensei's Avatar
Default 88 crx hf vs 92 civic vx
I watched this video and now I want to know if a 88 crx hf gets better mileage than the 92 civic vx? and if anyone has ever swapped the civic vx d15z1 vtec-e engine into an hf???Any feedback from owners of the two cars will be appreciated.As I'm planning to try this out. Here is the video the guy claims an average of 60 mpg.
http://www.ktla.com/pages/vide...rmat=
Old Sep 15, 2008 | 09:12 PM
sleepingciv's Avatar
Default Re: 88 crx hf vs 92 civic vx (guysensei)
good video
i have heard of people swapping for the z1 engine im not sure what it would do in the crx. if i was you id keep my hf and keep it tuned up the gas milage has to be pretty close for the hf and vx
Old Sep 15, 2008 | 09:25 PM
guysensei's Avatar
Default Re: 88 crx hf vs 92 civic vx (sleepingciv)
D15Z1
* VTEC-E
* Found in:
o 1992-1995 Honda Civic VX
o 1992-1995 Honda Civic VEi (European Market)
+ Displacement : 1493 cm³
+ Bore and Stroke : 75 mm X 84.5 mm
+ Rod Length : 137 mm
+ Compression : 9.3:1
+ Power : 90 hp (67 kW) @ 5600 rpm & 98 ft·lbf (133 N·m) @ 4800 rpm
+ Valvetrain : SOHC VTEC-E (4 valves per cylinder)
+ ECU Code : P07
+ Fuel Control : OBD-1 MPFI
D15B6
* Found in:
o 1988-1991 Honda CRX HFx
+ Compression : 9.1:1
+ Power:62 hp(88-89) 72 hp(90-91)@4500 & 83 ft·lbf(113 N·m)@2800
+ Valvetrain : SOHC (2 valves per cylinder)
+ Fuel Control : OBD-0 MPFI
+ Head Code : PM-8
Here are the engine stats. If the z1 is more efficient then it also has more hp. Which would make it a more desirable engine.
Old Sep 15, 2008 | 09:34 PM
well it is 28 more hp so it wouldnt be bad
in the light crx
88 hf 1819lbs
the vx is 2094
go for it let us know how it pans out
Old Sep 29, 2008 | 05:16 PM
guysensei's Avatar
anyone running a stock hf???
Old Sep 29, 2008 | 05:55 PM
mynameissangg's Avatar
I'd go with the zc. But yea nice vid
nycrx
Feb 12, 2006 12:44 AM
.(Lazarus).
Feb 10, 2003 06:17 PM
